Pulled rocker stud, and more? :( - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-04-2007, 07:38 PM
Gokussj5okazu's Avatar
Last journal entry: 336 Stroker: Teardown
This past Friday my 350 was running like absolute crap, like only 7 cylinders were firing. Finally got back home today and pulled the right valve cover since I was hearing a tapping on that side. First thing I see if the #4 intake rocker is extremely loose, but the nut it the same height as the others. So my pops makes me tighten it back down against my better judgement. You guessed it, it had been pulling out and as soon as I started it it pulled out even more. So a bit more of an inspection reveals that the #4 exhause rocker doesn't move at all, and neither does the pushrod. A little persuasion and I manages to push on the pushrod and force the lifter back into it's bore, once again against my better judgement. So now I've got a pulled rocker stud, and what seems like a lifter frozen in the lifter bore. Major PITA. And to top it all off, the old man, of course being a hard-headed so-and-so, says that drilling the stud hold out and tapping it for a screw in stud is a horrible idea.
So does anyone else have any ideas? Pinning the stud is out of the question, a certain SOMEONE's too hard headed to take it to the machine shop.
Old 03-04-2007, 07:52 PM
302 Z28's Avatar
There is a little more to it than just tapping the hole for a screw in stud. The stud boss has to be machined flat for the screw in stud to jamb against. Are you running stronger springs than stock? Are you winding it up too tight? In the old days a quick fix for puled studs was to pin them.
Vince
Old 03-04-2007, 07:58 PM
Ya I knew there was a bit more to it, and would have take it to the shop, but can't for the same reason as pinning it. They're stock springs, and it never sees anything higher than 4,500. If worse comes to worse I can swap the heads with another set I have, but the stuck lifter is what I'm really worried about.
Old 03-04-2007, 09:48 PM
You have machine the stud boss in order to install a shouldered stud and guide plates. I couldn't even guess how many people have pulled the loose stud, tapped the hole and put in a non shouldered stud and went down the road without pulling the heads. It's not the prefered way but if care is taken to keep the tap straight and get all chips out it can be done. Be sure use some sort of thread lock on the end of the stud that will go into the head.
Old 03-04-2007, 10:28 PM
GM Tech
There's actually a very economical and easy to use tool available from summit that is used to pull the stud and then, using the stud beside it, guides the tap so it goes in straight. Rockere arm stud removal/tap guide tool
Old 03-04-2007, 10:34 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
Beautiful.
Old 03-07-2007, 06:54 PM
Thanks Lil, I didn't even think of looking for tool for this. Seems we're just going put spacers on top of the rocker arm so we can lash it and hope the stud doesn't pull anymore. If it does, oh well, I'll pull it and tap it. I decided to pull the lifters while I'm at it, since one wasn't lifting. I really hope the lifter is just dished out too much and it's not the cam. Has anyone here every seen one do this?
Btw, how the hell do you get those suckers out? I'm used to driving them out from the bottom, but how are you suppose to pull them from the top. Anyone?
Old 03-07-2007, 09:45 PM
If you're going to run it on the old stud, knock it back down in the hole with a hammer. Put a plain nut on it so you don't bugger up the threads, and tap it down semi-gently until it's close to level with the next one. We did that to a friend's old Camaro years ago, and it not only got him home from Little Rock, it ran fine until the next time he over-revved it and pulled them back out again.
There's a tool for pulling lifters, but I've done it with a small screwdriver and a few choice words, if necessary. If they're not too gummed up, or beaten outward, at the bottom, they usually come out without too much trouble.
If the lifter bottom is dished, your cam is shot.
Old 03-20-2007, 03:31 PM
Well this is just giving me more and more trouble every time I touch it. Turn out the cam was shot, even with the new lifter there's no lift on that exhaust what so ever. >_> Luckily I got my hands on a free roller cam with lifters so now I just need to switch them out, right? Unfortunately wrong. The good tools that I'm going to be needing to take all of thsi apart this weekend are out at my shop (about 15 miles away), and I have no way of getting it there other than trying to get it to run and nurse it there. Anyhow now it won't run worth a crap, even worse than it did before I tore it down. Ya I know it's only running on 7 cylinders but heck, but it was before too, and atleast it could pull itself.
So now it's running extremely rich, which makes no sense since I never touched the carb while it was off. The new rockers are ticking slightly, my new valve covers were too tall causing the AC unit to move too far over and need a longer belt so I'm out power steering as well, AND I can't find an EGR block-off plate to same my life. All because of a 23 year old cam! Grrrr...
Are there any particular problems with running it on 7 cylinders, other than the horrible balance? I really don't care about bearing wear or anything else, as long as I can get it out there. We're most likely going to just finish up my other engine.
Old 03-20-2007, 03:51 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
You can get a EGR block plate Here: EGR
Sounds like , from ALL the problems you have posted on this engine, It just might be prudent to pull it ALL the way down and rebuild it..have the machining done AND you want to get the shavings from that smoked cam out of the system anyway..Start again with a NEW fresh engine.
This old one seems to be falling apart one part at a time...
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 03-20-2007, 04:14 PM
King of my Man-cave.
The material from that cam lobe and lifter (and probably some others) has travelled through your engine. It has scored the crank journals and cam journals. It has imbedded itself in your main, rod, and cam bearings. Some, if not all, of the pistons have metal particles imbedded in the skirts and will remain there to scratch the cylinder walls unless they are removed by glass beading the skirts. The cylinder walls are also scratched by the metal particles and will need to be honed. Your oil galleries are full of abraisive oil. Plus, the rocker stud will never stay put until you replace it with a screw-in stud.
You will have to remove the engine and tear it down to repair it, regardless of what the old man says.
tom
Old 03-20-2007, 04:20 PM
steve t's Avatar
ex biker, now hotrodder
i think he has a rebuilt motor ready to go from his post,
Old 03-20-2007, 04:28 PM
I don't see where he says that, but he's sure gonna need one.
tom
Old 03-20-2007, 05:19 PM
steve t's Avatar
he says he got another motor at the end, i just thought he was rebuilting it, anyway he will need something in better shape
Old 03-21-2007, 06:52 AM
I see it now. The last 2 words of the last post. How timely!
tom
