Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Pulled rocker stud, and more? :(
Old 03-04-2007, 07:52 PM
302 Z28's Avatar
302 Z28 302 Z28 is offline
There is a little more to it than just tapping the hole for a screw in stud. The stud boss has to be machined flat for the screw in stud to jamb against. Are you running stronger springs than stock? Are you winding it up too tight? In the old days a quick fix for puled studs was to pin them.
Vince
