Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Pulled rocker stud, and more? :(
  #17 (permalink)
Old 03-21-2007, 04:31 PM
docvette's Avatar
docvette docvette is offline
Wiki Edits: 12
Originally Posted by Gokussj5okazu
Are there any particular problems with running it on 7 cylinders, other than the horrible balance? I really don't care about bearing wear or anything else, as long as I can get it out there. We're most likely going to just finish up my other engine.
Doc here,
Oil contamination, rapid wear from metal shavings, main and rod Bearing wear, more cylinders going away, cam shattering, or locking up, are just a few..you STILL could end up walking that 15 miles AND then need a tow Vehicle..
Doc
