Pulled a wire threw now no power - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-07-2013, 09:00 PM
Back n the Game,Fully Hydrated
No power through the battery sources on the fusebox.
How do you get power back to the fusebox?
The radio has a fuse, so what protects the fusebox?
Large circle are the now dead ports.
The small circled connections have been moved to now work off the key ignition. How do I get battery back? run a line to from the battery to a new + distribution block?
Nothing is melted. This is so crappy, it doesn't work.
What functions as a fuse for the circled?
Old 04-07-2013, 09:30 PM
80s Gm vehicle. The constant bat power wire for my radion went to the bat source In the red circle. While routing the wire it brushed againt the pedal housing. I have no constant battery from many places. The fuseable link at the firewall is good. Where is the main box constant fuse for everything?
Im freaking out. I gonna blow.
Old 04-07-2013, 10:31 PM
Billie theres something you aint tellin us.
50 meter spread no sound.
I aint got time to bleed.
The jungle came alive and took him.
Give me da waepon
Get to the choppa
Old 04-08-2013, 12:55 PM
Please help
A momentary brushing of my radio memory wire on the brake pedal could not have taken out my whole fuse box constant battery source. There has to be a master fuse for the box somewhere.
All foreign cars have a main.
Old 04-08-2013, 02:15 PM
According to Haynes and Chilton there is no breaker box on the 1983. I cannot locate a main fuse.
GM sucks.
Just ask wants $29 to explain what happened.
The dealership wants $79-125.
I only wanted to keep my radio code. So I left the constant on.
I have traced the contiuity back threw the bulkhead. There must be some sort of circuit, breaker or not, because the terminal have no continuity.
Old 04-08-2013, 05:16 PM
EOD Guy's Avatar
How did you test the fuseable link? What make car is it? There should be a factory splice somewhere that connects the main battery feed to a fuseable link then to the fuse box
Old 04-08-2013, 08:18 PM
What year, what model?
ground power wire, dizzy problems? sh40674 Engine 2 03-26-2012 12:31 PM
how to tell if I threw a rod... cutthroatkid Engine 15 10-30-2009 04:46 PM
Help me wire my POWER WINDOWS! DarknessSpawned Electrical 20 12-07-2008 07:55 PM
Threw A Rod ! ! ! jbvcw71 Engine 21 09-03-2008 06:27 AM
Fuse amps & wire gauge for heated power seats? Sly's 53 Suburban Electrical 4 04-01-2005 04:38 PM
