In a while, Chet. |
Puller
Hi Dean, You can make a installer pretty easy from a long bolt the same size screwed in the crank and using a large , thick washer.Thread a nut down pulling your dampener on crank. The puller can be made from a 3/8 round plate with a nut welded (same size as crank bolt) in center. You need 3 , 7/16 holes to line up with holes in dampener to pull it off. You can use same long bolt to remove. Put washer (inside) dampener hole so puller bolt does not thread as you remove dampener. Sorry no pics. Hopes this helps. jim
It's only $23.99 at jegs..
http://www.jegs.com/i/Proform/778/66515/10002/-1 for $69.99 this one does both. http://www.jegs.com/i/Proform/778/66514/10002/-1 |
A puller does not need to be "Y" shaped.
If you take a piece of 3/8" or 1/2" piece of steel plate and drill 3 holes to bolt it to the damper and a center hole with a welded nut. Then get a piece of threaded rod for the center and you have a puller. Clear as mud? |
Advance and Auto Zone (if you have either there) has a tool loaner program, that is you simply leave the price of the tool for a deposit and when you return it they refund all your money. You do not have to be a regular customer nor do you have to buy your parts there the policy is to rent to anyone whether buying parts or not.
I must be drivin around without my damper as I don't own an install tool....
I never did use one either.But I bought one,And now I won't do without one.
My installer is a short length of 7/16"x20 all-thread with a nut and couple of washers and some HP grease. Use the fat OEM washer between the balancer and the 7/16" washers. I have used a small thrust bearing from an A/C clutch installation tool in the mix, and it works well if centered properly, and it eliminates the need for all the grease.
i used the advance auto loaner program . i just did mine this past saturday.
if you use a piece of steel 1/4" or thicker, against the damper, it is ok to beat it on with a large hammer, but DO NOT I repeat _DO NOT_ did I mention DO _NOT_ hit the balancer directly with a hammer!!!!!
allthough my buddy DID just install his with a plastic-faced "dead blow" hammer and it seemed to go on ok... |
| Recent Garage - Tools posts with photos |
| stripped threads in crankshaft using puller | sbcs10 | Engine | 8 | 03-13-2008 07:18 PM |
| pusher or puller electric fan?? | rolrandy | Engine | 7 | 09-11-2007 12:21 PM |
| Pusher or Puller ? | DrBee8457 | Hotrodding Basics | 16 | 08-13-2006 10:16 PM |
| Does anyone know a place to buy a hub puller? | Magnus_Jager | Suspension - Brakes - Steering | 4 | 10-05-2003 12:55 PM |
| Puller Fuel Pump??? | juveteach | Engine | 0 | 08-04-2003 07:52 PM |
