Pulley alignment - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-06-2008, 07:29 AM
Pulley alignment
Im having trouble aligning the pulleys on my 1980 camaro. The pulleys are new and are the deep V type. My problem is the water pump pulley, it needs to be shimmed out to align with the Alt and crank pulley. But after it is shimmed out, it no longer aligns with the power steering pulley. I can get the belts on, but they are definately off and the water pump pulley is being stressed and making noise. Any suggestions??? Should i shim the power steering pulley out and if so how do i do that?
Old 08-06-2008, 09:36 AM
$.06? fender washers sandwiched between the PS bracket and cylinder head mount bolts to act as a spacer will move it out and keep the alignment square
Old 08-06-2008, 09:47 AM
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
Go in to your local plumbing supply and pick up a piece of "schedule 40" black pipe in 1/2 inch O.D. Cut off what you need with a hack saw and grind to fit. The thick wall on this pipe will give you the rigidity that you need.
Washers are messy and sometimes you just can't keep them all together.
Also, you can move the pulley out a smidget on the shaft if you place a spacer behind it and re=tighten.
Old 08-06-2008, 10:49 AM
Power steering pumps are usually on a dedicated belt. Trying to get a v-belt to run everything like a serpentine will force the belt to try and deliver more power than it's designed for. Typically low power devices such as the water pump and alternator are on a common belt. Power steering and air conditioning compressors have theirs independently.
Bogie
Old 08-06-2008, 11:03 AM
good point alittle 1,
wrap the edge of the stack of fender washers with a layer of masking tape, start the bolt, if it shows, leave a bit of a tape tail so you can pull off the tape before tightening...
LOL, (I hate the stuff!) just a dab of 3M weather strip adhesive "yellow snot" will glue them together
Old 08-06-2008, 12:09 PM
Pulley alignment
are you running a aftermarket water pump ?
i had the same problem , took it back and again same mess .
bought it from hot rod parts place .
i put a stock one back on and no worries , fixed it .
try a stocker and see if you have a fix .
now if your bottom pulley is out farther than your power steering , i've run across this and the balancer wasn't all the way on .checked it with a square and measured off another engine .
stay in the groove
Old 08-06-2008, 02:09 PM
There are 2 belts, 1 goes around the crank, wp and alt, and the other goes around the crank, wp and pwr steering. The water pump is not aftermarket but the pulleys are. gonna play around with it this evening and see what i can come up with. Thanks for the replies
Old 08-06-2008, 07:13 PM
MI2600's Avatar
Member# 3287
I've used washers on various equipment. I cut a slot in a few washers so they could be placed onto the bolt after the bolt is installed loosely so that the proper alignment is achieved. When satisfied, you can replace the slotted washers with whole ones, or just leave them there.
March Pulley Alignment DeathRattle Engine 6 12-14-2006 02:56 PM
90s SBC Power Steering Pump pulley Removal Help Mustangsaly Engine 12 10-08-2006 06:00 PM
Strange pulley issue... Classix_Lover Engine 10 02-12-2006 07:12 PM
SBC Pulley Alignment Sky65 Engine 4 12-09-2005 10:45 PM
