Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - pulley stupid question
Old 03-16-2005, 02:54 PM
blndweasel's Avatar
blndweasel blndweasel is offline
paints everything flat black
Last journal entry: September 2005 - Current
your challenge with the PS pump is going to be mounting it properly so that you get good belt attachment / alignment.
you could go with a Saginaw power steering pump (and stock brackets) and hook it up to your existing equipment using hose adapters, but make sure to find out what pressure your stock PS pump produces. Saginaw pumps produce a lot of pressure... can't remember specifically but it's a lot. you obviously want to match the pressures as closely as possible if you're building a "frankensteering" setup.
