-   -   pulley stupid question (http://www.hotrodders.com/forum/pulley-stupid-question-59772.html)
280zxWith305 03-16-2005 12:42 PM
i've been looking for a waterpump and crank pulley for my engine... the ones in jegs are like 45 bucks a piece.. anyone know of anywhere better (cheaper) to find them? hell if anybody has any extra laying around ill even buy them off of ya... just PM me..
Siggy_Freud 03-16-2005 12:46 PM
Ebay and junk yards.
Silver_Camaro 03-16-2005 12:49 PM
Local part stores.. O'Reilly's, Autozone, Napa, CarQuest, etc..
poncho62 03-16-2005 01:00 PM
Are you planning on using the long or short pump? That is your 1st decision, as they take different pulleys.
Alternator and PS barckets are different too.
280zxWith305 03-16-2005 01:31 PM
well i think im going to use the long waterpump.. and for the power steering... the 280zx has hydraulic power steering.. do i need to use that power steering pump or a chevy steering pump? i had been thinkin about that lately also.. lol
poncho62 03-16-2005 01:36 PM
Don't know about that PS pump, but another way you could go is with the later model "serpentine" belt system. Just remember, that water pump turns the other way.
blndweasel 03-16-2005 02:54 PM
your challenge with the PS pump is going to be mounting it properly so that you get good belt attachment / alignment.
you could go with a Saginaw power steering pump (and stock brackets) and hook it up to your existing equipment using hose adapters, but make sure to find out what pressure your stock PS pump produces. Saginaw pumps produce a lot of pressure... can't remember specifically but it's a lot. you obviously want to match the pressures as closely as possible if you're building a "frankensteering" setup.
