pulley stupid question - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-16-2005, 11:42 AM
280zxWith305's Avatar
<--- Gas Bootlegger
i've been looking for a waterpump and crank pulley for my engine... the ones in jegs are like 45 bucks a piece.. anyone know of anywhere better (cheaper) to find them? hell if anybody has any extra laying around ill even buy them off of ya... just PM me..
Old 03-16-2005, 11:46 AM
Siggy_Freud's Avatar
Ebay and junk yards.
Old 03-16-2005, 11:49 AM
Silver_Camaro's Avatar
Superior Wheels Quality Tech
Local part stores.. O'Reilly's, Autozone, Napa, CarQuest, etc..
Old 03-16-2005, 12:00 PM
poncho62's Avatar
Wiki Edits: 5
Are you planning on using the long or short pump? That is your 1st decision, as they take different pulleys.
Alternator and PS barckets are different too.
Ontario Rodders
Old 03-16-2005, 12:31 PM
<--- Gas Bootlegger
well i think im going to use the long waterpump.. and for the power steering... the 280zx has hydraulic power steering.. do i need to use that power steering pump or a chevy steering pump? i had been thinkin about that lately also.. lol
Old 03-16-2005, 12:36 PM
poncho62's Avatar
Wiki Edits: 5
Don't know about that PS pump, but another way you could go is with the later model "serpentine" belt system. Just remember, that water pump turns the other way.
Ontario Rodders
Old 03-16-2005, 01:54 PM
blndweasel's Avatar
paints everything flat black
Last journal entry: September 2005 - Current
your challenge with the PS pump is going to be mounting it properly so that you get good belt attachment / alignment.
you could go with a Saginaw power steering pump (and stock brackets) and hook it up to your existing equipment using hose adapters, but make sure to find out what pressure your stock PS pump produces. Saginaw pumps produce a lot of pressure... can't remember specifically but it's a lot. you obviously want to match the pressures as closely as possible if you're building a "frankensteering" setup.
Im new but heres a stupid question. I hope it doesnt make a bad impression. Hellsinferno Engine 15 03-07-2011 05:52 PM
stupid question but need answer? fireforsin Engine 4 10-04-2004 11:18 PM
Stupid question... but 5.0 freak Engine 5 08-31-2004 06:47 AM
another stupid 305 question babygene41042 Engine 1 04-16-2004 04:47 PM
very stupid question ? pjsplayhouse Body - Exterior 3 11-09-2003 03:21 PM
