Pulley Thead bad looking for Tap. bolt 09440024 - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-06-2010, 12:00 PM
Pulley Threads bad, looking for Tap, bolt 09440024
Dear all, on the GM catalog it is a 7/16 - 20x2.25 300M POR
0.437" diameter
20 threats
is 2.25 the slope.
What tap do I need UNC or UNF
Most taps to buy are listed 7/16 20.
How do I pick the correct one?
BOLT, (7/16-20X2 1/4)
BR Mo
Old 10-06-2010, 12:42 PM
ericnova72's Avatar
More for Less Racer
7/16" - 20 is UNF(fine), 7/16"-14 is UNC(course)
Tap you need is 7/16 -20 UNF.
7/16" is bolt diameter(=.437"), 20 is threads per inch, UNF is Unified National Fine.
UNC is Unified National Course.
2.25 is the length of the bolt in inches, not the slope. You've been playing with metrics too much, haven't you
Old 10-06-2010, 02:28 PM
Hello Eric if I go after the ANSI table I have 20 threads per inch.
1 inch is 25.4mm. If I devide 25.4mm/ 20thread I get the slope 1.27mm per thread. Am I correct.
That 2.25 in is the lenght.
Than should be this the correct thread.
Thanks for your help.
7/16" - 20 UNF 0,438 11,112 9,90 20 1,270
Old 10-06-2010, 02:53 PM
ericnova72's Avatar
More for Less Racer
You are correct, 1.27mm per thread
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
Chevy 350 Crankshaft bolt removal 75gmck25 Engine 11 03-14-2008 06:27 AM
Transfer case - NP 203 - 205 jrm123180 Transmission - Rearend 2 03-24-2006 07:36 AM
ZZ4 water pump pulley bolt size Sly's 53 Suburban Engine 4 05-21-2005 04:17 PM
Bolt Strength Question jamnut Engine 16 03-30-2005 07:11 AM
