Pulling axles on Ford 8" - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-23-2005, 11:35 AM
Whippetguy's Avatar
Last journal entry: Window templates
I got a Ford 8" rear for my '29 Whippet Street Rod project (see Whippetguy's Journal). The unit is tight and in good shape, but I would like to pull the axles and 3rd member to check the bearings and replace the seals. When I tried to pull the axles with a slide hammer (after removing the retaining plate bolts, of course) the axle wouldn't budge. Do I just keep hammering longer and harder, or is there a trick I don't know about? Thanks for any help.
38 Chrysler Royal, original, unrestored
Old 10-23-2005, 11:44 AM
poncho62's Avatar
Wiki Edits: 5
They should pop out of there......probably just crud and corrosion holding them in......
Old 10-23-2005, 09:06 PM
they dont have c clips do they? or is that the 8.8?
Old 10-23-2005, 09:08 PM
poncho62's Avatar
Wiki Edits: 5
Does an 8" have a rear cover, or is it the pot type?
If it has a cover, it may have the clips.
Old 10-23-2005, 09:47 PM
lluciano77's Avatar
8" rears are exactly like 9". No covers, and removable centersections.
Keep pulling on the SOBs. They are hard to get the first time you take them out.
Old 10-23-2005, 10:29 PM
Sometimes they are easy........and sometimes they are rough.
I about snatched a almost NEW 69 Ford Torino off the jack stands trying to get a axle out back in 1970. Was going to change the gear ratio.
Last week I pulled the axles from a 57 Ford rear that has been in the MUD for at least 3 years.....and they came out by hand....no slide hammer, no pulling or anything.....The 57 rear was out of the car for years....lying behind a old radiator shop....
You just never know....but this will usually do the job....
Old 10-24-2005, 05:18 PM
Whippetguy's Avatar
I was told by several people here that they use a chain attached to the end of the axle and simply give the chain a few good tugs and the axle should just whip right out of there. I'll let you know if it works.
Old 10-24-2005, 06:21 PM
a 10 lb wieght on a slide hammer always works for me
Old 10-24-2005, 08:10 PM
take the torch and warm the airia behind the backing plate that is wher the bearing sits , dont get it to hot just enough to expand a bit. i use the brake drum turned backwards withe 3 nuts also backwards should work
Ford Ranger V8 Conversion nightrain_rod Hotrodders' Lounge 53 07-15-2009 11:45 AM
Poor Chevy Guy Needs help from F..F..ford Pro's 11echo Transmission - Rearend 3 10-06-2004 07:06 PM
Changing to 9" ford rearend... 11echo Transmission - Rearend 8 08-02-2003 11:09 AM
Ford 8" Rear mustang66maniac Transmission - Rearend 2 02-22-2002 03:14 PM
Ford 8" or 9"? Willy J Transmission - Rearend 2 11-30-2001 04:38 PM
