Re
Okay, I know im about to ask the same question again, but I just want clarification because today when I was picking up some ATF, I was told something new, as usual. I'm pulling the T5 out of my 88 Mustang because I don't have 5th gear and reverse. I understood that I could drop the driveshaft, unbolt the transmission from the bellhousing, slide the new transmission inn bolt it up to the bellhousing, connect drive shaft and all was good. Today, two guys said its not simple. That I had to pull the bellhousing to position the clutch fork on the spindle of the transmission?
By spindle you mean input shaft? I don't see why, if you're able to keep it steady, like on a jack, and thread it through the throwout bearing. I don't see any benefit to having the bell housing attached to the trans, except that you can put it up as an assembly maybe, I have never done that. Just ensure everything feels good, pedal pressure and all, before you wrap it all up.
I have taken 3" bolts, same size and thread as the trans mounting bolts, cut the heads of and used them as guide dowels. Makes it a little easier to get things aligned. If you're not removing the disc, you shouldn't have spline alignment problems. You do know you will have to raise and support the rear of the motor and probably remove the trans cross member to get the trans out?
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. Midnight Sun Street Rod Association |
| pulling a motor | mjascur | Engine | 4 | 09-12-2010 01:44 PM |
| I'm pulling oil in from somewhere | PrimeMover | Engine | 20 | 05-01-2006 06:02 AM |
| Which is better for pulling 383 or 400 sb | Chevy71 | Engine | 12 | 01-29-2004 09:14 PM |
| pulling tranny without pulling motor.... | Rubberman2003 | Transmission - Rearend | 20 | 06-26-2003 09:11 PM |
| Pulling brakes??? | Brian5 | Suspension - Brakes - Steering | 7 | 07-19-2002 06:59 PM |
