pulling transmission out of 74 nova - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-24-2004, 08:35 PM
I am trying to replace the torque converter in my 74 nova with a th350. I just rebuilt the engine have had it running and driven it a bit. I am waiting for a new radiator and in the time I thought I could put in a new converter. Today I tried to remove the transmission but got stuck when I could not get to the bolts holding the transmission to the engine block. I am thinking that I will have to take the engine off the motor mounts and slide it forward to get to the bolts. I really dont want to pull the engine again. Is there a better way to do this or does this sound good?
thanks
Old 04-24-2004, 10:21 PM
poncho62's Avatar
Wiki Edits: 5
Remove the rear crossmember and lower the back of the tranny, tilting it down enough to get the bolts with a long extension and socket.
Old 04-24-2004, 10:52 PM
Jmark's Avatar
Yep! that'll do it!
Old 04-25-2004, 10:46 AM
will I have to take the distributor out to tilt the engine and transmission back enough to get to those bolts. Will I have to take anything off, dist, coil, valve covers?
thanks
Old 04-25-2004, 10:51 AM
Jmark's Avatar
Probably just the dist cap is all. Get a real long 3/8" extension, 30" to 36" and a 9/16" swivel socket. It won't be a piece of cake, but its not hard either. The top 2 bolts on my truck are a pain to get to without atleast the 36" extension.
Old 04-25-2004, 01:04 PM
Thanks, I will give that a try
