What kind of things would I need to do to the suspension to pull the wheels higher off the ground. Thanks
Easy things - put battery in trunk, line rear bumper w/ lead, remove weight (remove sheet metal, add fiberglass) from fromt of car.
More work - Install a bigger engine, higher RPM range cam and proper higher stall speed torque converter. Lower rear gears always works. Move rear axle forward. [ January 27, 2003: Message edited by: willys36@aol.com ]</p> |
it also helps if you make sure your engine is secured to your frame with a little more then those usually oil soaked rubber mounts, in my 1971 nova i pulled a tear in my hood when i opended the throttle i fixed the enginemounts with solid selfmade bushing and welded my own mounts, this kept the motor in place and helped me lift my frontwheels a lot easier.
regards Bas |
