Pulsed Signal on Tach wire - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-15-2007, 09:31 AM
colin911's Avatar
Hey guys, I have a '85 Camaro, 305. Does anyone here know what signal is on the tach wire from the distributer? I know its a pulsed output, but is it pulsing off one contact, like one pulse per engine revolution? Or is it one pulse per contact (eight pulses per rev.?) I can't start my car at this time to measure it.
Thanks for any info
Old 09-15-2007, 09:44 AM
Should pulse for every cyl fired...
Old 09-15-2007, 12:54 PM
colin911's Avatar
That sounds right. In searching I've found that aftermarket shift lights have a setting for 4, 6, or 8 cylinder engines, so the signal must be different for each, hence 4, 6, or 8 pulses per rotation... right???
Old 09-15-2007, 01:07 PM
Holder350's Avatar
Auto Parts Professional
Correct, in reality the tach wire connects to the Neg side of the coil and senses the voltage drop when the coil releases its energy. thus 4 releases per turn on a V-8, 3 for a V or L6 and so on. Because only half the cylinders fire on each revolution.
This is my understanding on it anyway.
Old 09-15-2007, 01:50 PM
colin911's Avatar
Ahh, ok thanks, 4 pulses per rev. makes sense! Thanks so much for the help!!!
Cruise Control Compatibility with LED's? cboy Electrical 44 10-01-2010 12:08 PM
AMC tach, voltage meter and neutral saftey switch. Javelin360 Electrical 9 08-18-2007 03:50 PM
Universal turn signal install mbmopar Electrical 2 03-04-2006 09:26 AM
tach wire mhudak Engine 1 11-11-2004 10:10 AM
57 Chevy generator to altenator swap Rodrunner Electrical 2 07-17-2002 09:59 PM
