Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Pump gas safe?
Thread: Pump gas safe?
Old 02-10-2013, 10:12 AM
ap72 ap72 is offline
Banned
with your combo and a really good tune and you'll be fine on 91 octane. I'd also only run a 180 tstat (or fill the block to the water pump holes and run a 160)
I know its money but a knock detector would be a BIG consideration, for when the weather changes or you get some bad gas. A combination this close is doable BUT you need a spot on tune.
