Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Pump gas safe?
Thread: Pump gas safe?
Old 02-11-2013, 02:10 PM
Landshark928's Avatar
Landshark928 Landshark928 is offline
FrankenPorsche
If that was your static, no problem. Your a good bit high for DCR. Need a bigger cam to bring SCR down, or you need to drop the SCR. Or run E85...
Post up your values here and someone can double check your work.
