Pump gas safe?
Ok guys, I'm working on a 350, 64 cc alum heads, forged piston etc...Putting values in "Patt Kelley" 's calculator, we got 9.27 for DCR , same number with KB's. KB's also gives 9.98:1 for SCR. Are these safe with pump gas (max 91) or we need to lower this?Any ideas appreciated..
Those knock sensors are a hell of alot cheaper than the alternative repairs.A extra step to wire in??. Yes, but well worth it.
IMHO, 9.27 is really really high for DCR, but then again i myself do not have practical proof for that
![]() ![]() taken from this article: Engine Compression Ratio - Tech - Popular Hot Rodding Magazine anybody done it just correct me, i'm willing to learn
If that was your static, no problem. Your a good bit high for DCR. Need a bigger cam to bring SCR down, or you need to drop the SCR. Or run E85...
Post up your values here and someone can double check your work. |
Thank you all for consideration.
Here I got : sbc 350 STD to be bored to 0.040 (never decked), cast crank , Probe FPS Flat top -4 cc, forged rods (5.7") , 64 cc aluminum heads (190 cc runners, 2.02/1.90), 1.5 ratio roller type rockers , Howard Hyd. 110041 cam (Duration :235 Ex, 225 In - Valve lift:.488 Ex ,.465 In. - 110 LC - 106 Intake C/L -Intake closes @38.5 deg. ABDC ), Head Gasket Fel pro 1003 (4.166 Dia, 0.041 compressed thickness) Not sure or insufficient information about quench distance stuff or decking. Any comment or help is really appreciated. |
You're right boogie... apparently I put " Duration @ .050" instead of "Advertised duration" which are different. With corrected input, I got 10.0:1 for SCR and 7.93 for DCR. Looks safe to me.
that sounds about right, should be good to go! which calc are you using with the adv. duration? i've had quite some variations from the various calculators when it comes to determining DCR from IVC cam timing (0.050 vs. 0.006, 0.004 etc)
| Pump Gas Versus Race Gas / dyno results ?? | fastlaners | Engine | 8 | 04-30-2011 10:51 PM |
| Is it normal to have to pump the gas several times to get accelerator pump squirt ? | fumplet | Engine | 3 | 11-16-2010 01:14 PM |
| mixes marine gas and regular pump gas | crussell85 | Engine | 3 | 08-20-2010 08:19 PM |
| mixes marine gas and regular pump gas | crussell85 | Engine | 4 | 08-19-2010 06:30 AM |
| Fuel Pump Not Sending Gas To Carb Why?? Its Not Electric Fuel Pump???? | zeeman19 | Engine | 7 | 02-13-2007 03:17 PM |
