pump gear lube - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-04-2008, 10:39 AM
pump gear lube
I have a th350 that the case broke in and I transferring my old into the new. Everything was less than 10,000mi and it worked grate before. Do I need to take the bump halves apart and grease the gears?
Old 01-04-2008, 02:16 PM
pump gear lube
Yes and I suggest using pudding. I prefer chocolate myself. Although vanilla will work, in a pinch...........
Well, you are tomthecomic, so I thought you may get a kick out of that response.
I would not take the pump apart to lube the gears, but instead make sure the gears turn freely, then if you want, dump some trans fluid on them via the seal area.
Old 01-04-2008, 07:06 PM
what now
Crap I only read the first part. Now how do I get pudding out?
Old 01-04-2008, 07:44 PM
pump gear lube
Now see, that is why you are tomthecomic!
Old 01-04-2008, 10:06 PM
79C10's Avatar
Viva la Migra!!
A case of the munchies and a bendy straw!
Hyd. Roller lifters problems hotrodf1 Engine 121 10-25-2007 01:31 PM
Rear end gear ratio change = spedo. cable gear change. help? turbo 350 sugar ray Transmission - Rearend 6 07-18-2007 11:32 AM
rear end gear lube camaroboy1991 Transmission - Rearend 12 04-27-2007 02:38 PM
More TECH On FORD Dist. Gear Failure KULTULZ Engine 8 03-18-2003 04:50 AM
80/90 gear lube ok for sm-465 and non possi rear end? zachscc Transmission - Rearend 2 03-02-2003 05:06 AM
