pump seal - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-26-2006, 11:48 PM
markzepp820's Avatar
pump seal
I have a leak on the front side of my TH400. I'm guessing its the front pump seal? Tranny fluid is always leaking slowly on the flywheel cover. If it is the front pump seal, is it required to remove the tranny? thanks
Mark
Old 09-27-2006, 06:12 AM
BOBCRMAN@aol.com's Avatar
Yup, the trans has to come out! Then pull torque converter, check hub. Pry out old seal. Install new seal. Properly install converter.
Old 09-29-2006, 08:09 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Mark
I'd be checking the pump hub bushing in the pump before sticking in a new pump seal only.
IF the bushing has walked forward into the seal it's self , NO new seal will stop the leak.
TH-350 front pump seal nova72000 Transmission - Rearend 9 09-23-2006 03:17 PM
Electric fuel pump bad or not? HotRodMan Electrical 4 09-10-2005 09:47 PM
Front oil pan seal on Small Block Chevys gearhead77 Engine 19 09-26-2004 08:58 PM
Rear Main Seal 1985fiero Engine 1 04-27-2004 09:31 PM
holley accelerator pump 87 350monteSS Engine 8 07-18-2003 06:51 PM
