Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Pump them up?
Thread: Pump them up?
Old 01-31-2013, 03:35 AM
painted jester's Avatar
painted jester painted jester is offline
TAKE A KID TO A CAR SHOW
Last journal entry: Wifes 79 comeing together!
There are a couple of lifter that are pumped up before installation usually ant pump 0 lash types and Rhoads lifters! So a person needs to read directions!
Jester
HOW TO's: ORIGINAL RHOADS LIFTERS
Before installation, each Rhoads Lifter should be fully filled with oil. To fill with oil, completely submerge each lifter upright into a container of oil and compress the inner plunger with a pushrod or screwdriver until the plunger is driven to the bottom of the lifter. Hold several seconds and release slowly. Repeat several times until the lifter is fully filled. NOTE: Soaking lifters in oil will not fill them. Also, make sure to apply assembly lube to each cam lobe and lifter bottom!
To understand and adjust your lifters go here:
http://www.crankshaftcoalition.com/w...raulic_lifters
Good night Wezz its 4:30 A.M. here!!!
