Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Pump them up?
Thread: Pump them up?
  #19 (permalink)
Old 01-31-2013, 10:16 AM
vinniekq2's Avatar
vinniekq2 vinniekq2 is offline
hydraulics
Originally Posted by Wezz View Post
I m not going degree i want to set it by hand like the other link says
wezz
there are 2 kinds of engine builders
1: guy buys parts,gets things machined,assembles engine,installs it and drives it
performance=depends on luck
builder 2:
guy meticulously chooses matching parts that work well together, gets things machined and very carefully checks all the parts for perfect fit,makes any and all corrections as he goes. assembles all parts making triple sure all parts are perfectly in sinc,hand fits crucial elements like piston to wall,piston to valve,exact phasing of cam timing,test fits cam plus and minus 4 degrees incase he decides to retune valve timing at a later date.Installs the engine and then after proper break in,spends several hours doing a detailed tune up including often over looked things like adjusting air bleeds and jetting to get perfect A/F ratios for his/her purpose,same for F.I. but done differently.Ignition is tuned to the cars application.
which class are you in?
