Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Pump them up?
Thread: Pump them up?
  #45 (permalink)
Old 02-01-2013, 02:25 PM
painted jester's Avatar
painted jester painted jester is offline
Last journal entry: 383 BLAH, BLAH.
What model vehicle, year, cu.inch.,roller or flat tappet cam?
Jester
Pull the cam look down the cam bore and see if when you pulled the cam some gunk or obstruction is stopping the cam from going back all the way? Or if when you installed you didn't hit a bearing with a lobe creating an obstruction making the cam fit tight? Does the cam spin easy?
