Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Pump them up?
Thread: Pump them up?
  #47 (permalink)
Old 02-01-2013, 03:31 PM
painted jester's Avatar
painted jester painted jester is offline
TAKE A KID TO A CAR SHOW
Last journal entry: Wifes 79 comeing together!
Originally Posted by Wezz View Post
The block is a 14093627. A tbi afther 86 The cam is a edelbrock performer 3702 disgned for a 305- 350 Tbi and lg4 v8 engines. The lube that i put on the cam make spin a lettle harde but i can spin the cam around
Even with heavy break in lube it should turn with very little effort! Did you have cam bearings installed? If you gobbed a lot of cam lube on the rear of the cam it can hold the cam out a little it has no way to escape that area in the rear of the block creating a hydo. lock! I only put the break in lube on the cam lobes and lifters and break in oil on the bearings and cam surfaces that ride on the bearings! You can knock the plug out in the rear of the block and see how far the cam is going back! and replace with a new plug after! What timing chain are you using ?
Jester
