Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Pump them up?
Thread: Pump them up?
  #51 (permalink)
Old 02-02-2013, 03:29 AM
painted jester's Avatar
painted jester painted jester is offline
Last journal entry: 383 BLAH, BLAH.
Wezz: Yes GOOD
unless there is a problem you just leave off the retainer thrust plate use lube on the surface where the cam gear rides and install the older style timing chain and gears, remember to put locktite on the timing gear bolts! just like on an early block! Is your fuel pump actuating rod hole drilled for a mechanical pump! or are you using an electric?
Jester
