Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Pump them up?
Thread: Pump them up?
  #189 (permalink)
Old 02-06-2013, 03:23 PM
painted jester's Avatar
painted jester painted jester is offline
Last journal entry: 383 BLAH, BLAH.
Originally Posted by Wezz View Post
@ malc i have a old distribitor. With a dril works fine right?
REMOVE THE GEAR AND CUT OFF TOP OF SHAFT AT ADVANCE WEIGHTS!!!!! You probably all ready did
Ford or chevy its pretty much the same!
You can not use the shaft alone you need the housing or the bottom of the housing to complete the oil gall. or the oil won't flow to the rest of the block!!!!!
Jester
