Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Pump them up?
Thread: Pump them up?
  #226 (permalink)
Old 02-18-2013, 11:01 AM
painted jester's Avatar
painted jester painted jester is offline
Last journal entry: 383 BLAH, BLAH.
post a pic of the length checker on the stud with the push rod in place! If the seats were cut high the valves would set closer to the pistons making the valve stems shorter above the head and if the valve stem tips were dressed that would make them shorter by more! If you had valve springs installed to match the cam why did he install the rotators? Check your spring hight with the rotators installed are all the springs at the same height with valves closed? Rotators decrease the spring hight call the cam techs and see if you should run rotators with that cam! I would remove them! And set spring hight! I thought you bought a spring kit?
Jester
