Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Pump them up?
Thread: Pump them up?
  #233 (permalink)
Old 02-18-2013, 06:59 PM
painted jester's Avatar
painted jester painted jester is offline
Last journal entry: 383 BLAH, BLAH.
Originally Posted by Wezz View Post
Can you explain why its not fitting the puschrod tool. When the valvelifter is full ? And do you see the the puchrod in the rockerarm hole where the oil is coming tru. Its not totally going open. You still see a little of the pushrod .. Bad??
Put a straight edge across the tops of all the valve stem tips all 8 on each head are they all touching the straight edge or are they staggered?Like in the pic? some touching some not! send a pic!
http://www.hotrodders.com/forum/atta...1&d=1361238765
It should be fine, The wear print looks good, if the tool is that close on all the valve tips,The lifters rotate in their bores as you break in the cam everything will settle in and be fine,make sure you prime the engine as you turn the crank slowly till you see oil at the rockers!
Jester
