Pump them up? - Page 16 - Hot Rod Forum : Hotrodders Bulletin Board
  #226 (permalink)
Old 02-18-2013, 11:01 AM
painted jester's Avatar
TAKE A KID TO A CAR SHOW
Last journal entry: Wifes 79 comeing together!
post a pic of the length checker on the stud with the push rod in place! If the seats were cut high the valves would set closer to the pistons making the valve stems shorter above the head and if the valve stem tips were dressed that would make them shorter by more! If you had valve springs installed to match the cam why did he install the rotators? Check your spring hight with the rotators installed are all the springs at the same height with valves closed? Rotators decrease the spring hight call the cam techs and see if you should run rotators with that cam! I would remove them! And set spring hight! I thought you bought a spring kit?
Jester
  #227 (permalink)
Old 02-18-2013, 11:27 AM
the youngone
Last journal entry: progressthe
No origional springs are installed. The origional. Tbi springs. Would work. With the cam. Says the edelbrock website but it cant be wrong becouse it is the same lenght as the. Old lifter and rods .. I measure that And the rockerarms are in the middle of the valve stem. Thats good. Right ?
  #228 (permalink)
Old 02-18-2013, 12:24 PM
post a pic of the length checker on the stud with the push rod in place valves closed #1 top dead center!
Jester
  #229 (permalink)
Old 02-18-2013, 04:14 PM
the youngone
pic
with a empty lifter if i press slightly on the chekker tool it looks like picture 1 wit a full lifter it look like picture 2 i dont understand why its not correctly old lifter and old pushros is the same lenght as a nw lifter and a new puschrod... @ the machineshop they grind my valve seat but they also grinded the tip of the valve stem, so that has to be the same as before ,,
  #230 (permalink)
Old 02-18-2013, 04:21 PM
the youngone
the yello paper shows how the rockerar touches the valve stem... looks good to me?? ImageShack Album - 5 images
  #231 (permalink)
Old 02-18-2013, 05:01 PM
Yes, It looks good!!! put break in lube on the ends of the rocker arms and balls! your good to go
Jester
  #232 (permalink)
Old 02-18-2013, 05:05 PM
the youngone
Can you explain why its not fitting the puschrod tool. When the valvelifter is full ? And do you see the the puchrod in the rockerarm hole where the oil is coming tru. Its not totally going open. You still see a little of the pushrod .. Bad??
  #233 (permalink)
Old 02-18-2013, 06:59 PM
Put a straight edge across the tops of all the valve stem tips all 8 on each head are they all touching the straight edge or are they staggered?Like in the pic? some touching some not! send a pic!
http://www.hotrodders.com/forum/atta...1&d=1361238765
It should be fine, The wear print looks good, if the tool is that close on all the valve tips,The lifters rotate in their bores as you break in the cam everything will settle in and be fine,make sure you prime the engine as you turn the crank slowly till you see oil at the rockers!
Jester
  #234 (permalink)
Old 02-18-2013, 11:28 PM
the youngone
Yes jester the tool is to all valve stems about the same like picture 2 so its just sligtly not touching the valvestem.. But if i look at the. Wear on the stem its in the middle . I will make a pic from the stems with a straight linial on it .. Do they al need to touch the straight line?
  #235 (permalink)
Old 02-18-2013, 11:43 PM
If they are close it will be ok all the same hight is best, but if the gaps are wide you may have to run different push rods on individual cylinders or have your high valve stems dressed down! you might also run lash caps on a few valve stems!
I really don't think you'll have a problem running those push rods by the pictures you posted but I would like to see your pics with a straight edge first!
Lash caps
http://www.hotrodders.com/forum/atta...1&d=1361256181
  #236 (permalink)
Old 02-18-2013, 11:53 PM
the youngone
Ok will make a pic tomorro . I have to say i already. Adjust the. Rockernuts and when i crack the engine without sparkplugs. Cranking by hand oufcourse it al opens and. Close nicely but i will make a pic
  #237 (permalink)
Old 02-18-2013, 11:54 PM
the youngone
What i want to say with it also without the lashcaps i can adjust the rockernut without a problem.
  #238 (permalink)
Old 02-19-2013, 12:44 AM
the youngone
And how about the valve springs .. I have totators. Actually will leave them in .. I chekked the internet and i read that you can use stock springs . Can u confirm that to me ?
  #239 (permalink)
Old 02-19-2013, 01:21 AM
the youngone
Cam ideas... [Archive] - NastyZ28.com. Conclusion on this. Treath is i can use stock springs right??
  #240 (permalink)
Old 02-19-2013, 02:13 AM
the youngone
Stock
This is what edelbrock says..
Electric fuel pump, fan and water pump Curtis Thornton Electrical 9 05-08-2011 01:41 PM
Is it normal to have to pump the gas several times to get accelerator pump squirt ? fumplet Engine 3 11-16-2010 01:14 PM
Fuel Pump Pushrod/ Pump Mounting Plate (SBC) clicketyclack Engine 2 07-10-2010 11:08 AM
Electric fuel pump to manual pump engine.. RookieRodder Hotrodding Basics 7 02-14-2008 05:28 PM
Th-350 pump reassembly - position of gears and pump halves? Warrant Transmission - Rearend 1 06-02-2006 10:04 PM
