Pump them up? - Page 17 - Hot Rod Forum : Hotrodders Bulletin Board
  #241 (permalink)
Old 02-19-2013, 09:30 AM
painted jester's Avatar
TAKE A KID TO A CAR SHOW
Last journal entry: Wifes 79 comeing together!
"And how about the valve springs i can use stock springs right??"
Yes you can use the stock units, if the pressure at installed hight is correct!
On a hydraulic cam when you preload the lifters, the plunger will change the pushrod position!
A 3/8" rocker stud has 24 threads per inch. You generally pre load the lifters about 1/2 to 3/4 turn stock setting, which will put the rocker arm about 0.021" to .03?" lower This needs to be considered as well. So your push rods should work fine! If the valve stems are equal length above the head!
You are building a basically stock flat tappet cam engine with a little more power. the demand on your valve train isn't that demanding, and the basic hydr. lifters are designed to compensate for minor differences in expansion, wear, etc. when hot your lash can change from .006" to .020" depending on component materials! The lifters will compensate for this if adjusted cold and when readjusted hot your push rods will be .006 to .020 closer to the rocker!
If you were building a full out race engine it would be more demanding on the tighter tolerances in order to stand up to the demand put on the valve train!
The rocker arm tip should be in the center of the valve stem tip at half its travel when opening the valve, when lifters are pumped up after engine is primed. The only thing that can make a problem with the push rods I sent you is : If the head was milled, valve seats installed and machined high, valve stem tips machined, different length valves installed, a thick head gasket, Cam grind,etc any thing that moves the valve train closer or away from the cam lobe will change push rod length! If your valve stem hight looks good in the pics you post: you will be able to run those push rods!
Jester
  #242 (permalink)
Old 02-19-2013, 09:56 AM
the youngone
Last journal entry: progressthe
What do you mean with preload ... Leave them a night in the oil ? The picture where the chekker seems to fit is with a not fully load lifter i could press the pushrod a litle in the lifter the picture where the chekker not seems to fit is a fully load lifter. I cant pres it in The heads are milled a little. Valves are regrind but to compensate that. They grind a little of the valve stem .. The center of the rocker is touching the middle on the valve stem.. Like you see on the picture. .. To if its going to work Are the lifters getting pressed in a little ?
  #243 (permalink)
Old 02-19-2013, 11:07 AM
After they are installed and initially adjusted !!!!! After your engine is assembled When you prime the engine with oil, your lifters will fill with oil (load) "PRE" start up! Do you under stand what I meant by preload? I meant prime! Sorry!!
Yes your lifters are collapsing a little.
The tool touching the push rod and valve tip is perfect! the other is close
Jester
  #244 (permalink)
Old 02-19-2013, 11:22 AM
vinniekq2's Avatar
PJ is this your first correspondence student? Im impressed with the details and patience.Wezz you might get a bill for another chunk of marzipan,lol. I hope this engine runs as good as it sounds,will be a huge accomplishment for a first time builder
  #245 (permalink)
Old 02-19-2013, 12:01 PM
Vinnie
Just a small language problem LOL we're getting there Wezz is doing a good job and he cares about the build Cant say that about everyone on hereLOL
Jester
  #246 (permalink)
Old 02-19-2013, 12:38 PM
vinniekq2's Avatar
I agree,I know I dont mind going the extra mile to help,if the person is really trying. Thats how a lot of times you go to offer suguestions and come home very late with dirty hands
  #247 (permalink)
Old 02-19-2013, 04:33 PM
the youngone
Jester i mean the rodchekker is like the pic not fitted with a fully lifter .. With an emty lifter and when i puch in the liter/rodchekker a bit its fitting perfect like the pic says .. So is it good yes or no haha .. Alsoo ik have a weiand exelerator. Manifold and a edelbrock torker 2 wishone will be the best. I also have a. I think a edelbrock 650 carb will it work on my ported heads ?
  #248 (permalink)
Old 02-20-2013, 12:28 AM
The Weiand X-celerator will match your rpm ranges better then the torker with that cam and the 650 should work very well on it with some minor initial tuning!
The push rods should be fine when you adjust the lifters! I need to see the straight edge across the valve tip pics. Then we will go from there.
Jester
  #249 (permalink)
Old 02-20-2013, 12:33 AM
the youngone
Ok I cant show you the. Edge on the valvetips becouse when i adjust om not going to lose them again... Over the carb what do you mean With minor initial tuning? Is.a 650 on a 305 not to big?? Btw how can i chek what for carb it is ..
  #250 (permalink)
Old 02-20-2013, 12:27 PM
Wezz:
When you install a carb, there is an initial tune for idle, mixture, accelerator pump squirt and duration, secondary timing ETC. just all basic tuning when you first install a carb! every engine has different demands!
There is a list # on the choke horn if its a Holley, post it! If its a 650 it should work fine with your build
You already adjusted the lifters? OK, that's fine if they are all running on the center of the valve tips you will be fine. Finnish your assembly
Jester
  #251 (permalink)
Old 02-20-2013, 12:32 PM
the youngone
No not assambled yet .. But now there are no stiper on the valve tip . Uhm btw its a edelbrock carb .. Gues a 650 what the man told me .. Here is a pic
  #252 (permalink)
Old 02-20-2013, 12:35 PM
the youngone
Carb pic
Here the pic
  #253 (permalink)
Old 02-20-2013, 12:56 PM
the youngone
I chekked the numbers on the carb its 188 9635sa .. And the web says its a gm???
  #254 (permalink)
Old 02-20-2013, 02:02 PM
That looks like a carter? Not an Edelbrock!
Jester
I checked the # Its a Carter 625 cfm!
  #255 (permalink)
Old 02-20-2013, 02:13 PM
the youngone
And is that a good one??
Electric fuel pump, fan and water pump Curtis Thornton Electrical 9 05-08-2011 01:41 PM
Is it normal to have to pump the gas several times to get accelerator pump squirt ? fumplet Engine 3 11-16-2010 01:14 PM
Fuel Pump Pushrod/ Pump Mounting Plate (SBC) clicketyclack Engine 2 07-10-2010 11:08 AM
Electric fuel pump to manual pump engine.. RookieRodder Hotrodding Basics 7 02-14-2008 05:28 PM
Th-350 pump reassembly - position of gears and pump halves? Warrant Transmission - Rearend 1 06-02-2006 10:04 PM
