Pump them up? - Page 18 - Hot Rod Forum : Hotrodders Bulletin Board
  #256 (permalink)
Old 02-20-2013, 02:50 PM
painted jester's Avatar
TAKE A KID TO A CAR SHOW
Last journal entry: Wifes 79 comeing together!
Carters are much better then edelbrocks in my opinion! But I cant tell you that one is good,It looks rough, and if the internals have corroded or small passages pluged or gaskets have shrunk! You would be better off getting a rebuilt or new carb Then fooling with the old carter! That carb came on the early 348-409 , 396-427 and hasn't been produced in many years!
C-4 AFB Carter Rebuild Kit
Fits: 9502 9504 9205 9635 9636 9637 9755 9641 9758
Part #5281
http://www.carburetion.com/Carter4.htm
  #257 (permalink)
Old 02-20-2013, 03:04 PM
the youngone
Last journal entry: progressthe
So would you recomend a new one or sandblast it and get a revision kitt
  #258 (permalink)
Old 02-20-2013, 03:56 PM
DON'T SAND BLAST IT!!! Gunk it!!! and blow out the passages with the spray carb. cleaner and blow it off with air, use a brush if necessary!
Jester
Carter AFB 9000 Rebuild - Part 4 of 6 - YouTube
  #259 (permalink)
Old 02-20-2013, 04:08 PM
the youngone
Is that The carb i have on the video .. And can you send me a revison kit for my carb from summit or so . Wil it work btw on my 305 with a weiand ? Jester tnx for the help !
  #260 (permalink)
Old 02-20-2013, 04:40 PM
Yes thats your carb on the video
Take the carb apart completely and thoroughly clean all of the pieces in the gunk Among the spots in a Carter carburetor that can get the most built-up are bleed vents, so make sure to get these as clean as you can. The best way to clean the parts is to soak them in carburetor cleaner overnight some a couple of days. Before putting the pieces together, take them out of the carburetor cleaner and brush them down with a small hand held brass wire brush, wear safty goggles and gloves then blow the carburetor off with compressed air. Make sure to blast air through every hole in every component of the carburetor use a small wire in the holes if needed to dislodge material but dont push so hard as to jamb a build up in the hole
including the needle valves, float valves and bleed vents. blow back in the opposite direction as you pushed the wire! Use spray carb cleaner all the while you are cleaning so as nothing dries and adheres in the carb passages!
Wezz dont use the carb cleaner around any lit pilots or open furnace flame Etc, you will have an explosion, and wear a ventilator mask with a carbon filter!!! The ones for car painting are very good if your in an inclosed area!!!!
throttle shafts, will need extra care, These pieces must keep their shape as closely as possible. If the throttle shaft loses too much metal due to excessive scrubbing or sanding, you may get a vacuum leak through the shaft bores the shaft bores are also very impotent to keep their shape and size do not sand or run a stiff wire brush through them just run a swab with carb cleaner through them like swabbing a gun bore!!
Jester
  #261 (permalink)
Old 02-20-2013, 06:12 PM
the youngone
Hahah. I know the carb cleaner stuff its pulling out your loungs haha Uhm. Where can i buy the rebuild kitt. For my carb .. Will it work with a weiand exelerator ?
  #262 (permalink)
Old 02-20-2013, 06:21 PM
It will work with the X-celerator yes!
See if you can get parts locally! Or heres a good place
Carter 4 AFB Parts Page
Jester
  #263 (permalink)
Old 02-20-2013, 06:41 PM
the youngone
Carb
Haha jester why dont u come to holland. Like a vakation i will show you everything of my country haha . But uuh. Is the next pic i send the kitt i need? Thnx
  #264 (permalink)
Old 02-20-2013, 06:45 PM
The basic kit is part#KT-5281
Jester
http://www.hotrodders.com/forum/atta...1&d=1361411113
  #265 (permalink)
Old 02-20-2013, 11:51 PM
the youngone
O yes thats the pic i meant haha
  #266 (permalink)
Old 02-21-2013, 12:09 PM
the youngone
I callt the. Shop near by he said its not from gm ? He said its the same as a edelbrock.. I think he dont know much of it haha . How much cmf do you think the carn is ? Btw today i cleaned my. Weiand manifold. Pics are coming
  #267 (permalink)
Old 02-21-2013, 04:50 PM
the youngone
here the pics i smoothet the runner of the intake a little .. ImageShack Album - 4 images and the pic where i put a tiwrap in it is it a rod in there ?? or is it good like its now..
  #268 (permalink)
Old 02-21-2013, 04:52 PM
the youngone
intake en carb
ohyeh i heart the man say in the video if there is a number on the carb what says:9635sa its a 600cfm.. it that right??
  #269 (permalink)
Old 02-22-2013, 12:18 PM
the youngone
Another question .. I soaked the lifters in oil for a few nights but now i cant press them inn by hand ?
  #270 (permalink)
Old 02-22-2013, 01:20 PM
the youngone
E few are soft mostly is hard .. When i take the arecompressor and blow in the small hole a little its hard wichone is good hard or soft
Electric fuel pump, fan and water pump Curtis Thornton Electrical 9 05-08-2011 01:41 PM
Is it normal to have to pump the gas several times to get accelerator pump squirt ? fumplet Engine 3 11-16-2010 01:14 PM
Fuel Pump Pushrod/ Pump Mounting Plate (SBC) clicketyclack Engine 2 07-10-2010 11:08 AM
Electric fuel pump to manual pump engine.. RookieRodder Hotrodding Basics 7 02-14-2008 05:28 PM
Th-350 pump reassembly - position of gears and pump halves? Warrant Transmission - Rearend 1 06-02-2006 10:04 PM
