Pump them up? - Page 22 - Hot Rod Forum : Hotrodders Bulletin Board
  #316 (permalink)
Old 02-26-2013, 05:30 PM
the youngone
Last journal entry: progressthe
Ok. Thats the best at low rpm and whats the best at a higer rpn like 3000.3500.. Where to buy a spacer ? I have this. Intake almist for nothing i clean it up so nowin doubt wat to do!
  #317 (permalink)
Old 02-26-2013, 05:36 PM
painted jester's Avatar
TAKE A KID TO A CAR SHOW
Last journal entry: Wifes 79 comeing together!
Check my last post!! See the 4 hole plate? That is the old x-celerator intake you have it isn't to bad at lower RPM 1500 rpm up!!
X-CELerator Intake Manifold
1957-86 Chevy 262-400ci
1987-Up w/Aluminum Heads
4150 Carb Flange
1500-6500 RPM Range
Jester
  #318 (permalink)
Old 02-26-2013, 05:40 PM
the youngone
Ok thnx jester . Is it worth wil my engine not run with this intake ... Is the plate expensive?
  #319 (permalink)
Old 02-26-2013, 05:46 PM
the youngone
haha jester now i see your post with the numbers.! nombers dont lie! 900 is idle .. 1500 is the start of pedal to the metal!
  #320 (permalink)
Old 02-26-2013, 05:55 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If it was ME, I would build it using the Weiand intake and see what it ran like. If you're happy w/it, then nothing needs to be done. The difference won't be worth $hipping a different intake from the US to you.
Just keep your eyes open for a Performer intake. When/if you find one, you can decide if you want to swap.
If you have room for a spacer, you can make one from marine plywood.
A couple I made:
  #321 (permalink)
Old 02-26-2013, 05:56 PM
15 to 30 dollars depending on the brand! years ago we made our own out of hardwood or Neolite or aluminum as heat insulators you could probably make one!!! make a pattern out of the intakes carb base Or make an anti reversion plat like this only with longer tubes!!!
http://www.hotrodders.com/forum/atta...1&d=1361922978
Jester
Like Cobalt says run it and see
  #322 (permalink)
Old 02-26-2013, 06:00 PM
How about cobalt and I are thinking the same thing and posted at the same time LOL
Jester LOL
  #323 (permalink)
Old 02-26-2013, 06:02 PM
the youngone
oke this is what i want to do. i run the engine on a stand .. and the carb is going of the block when i bould it in.. it ti runs like a dog on the stand i can make a plate of steel or rvs. what disign would be better the first one with only holes or the second post with tubes, how thick needs the plate with tubes to be and how long tubes.. maybe angle the tubes to the direction of the 1 and 3 port and 2 and 4 port and the 5 and 7 port and a tube to 6 and 8,,, idea?
  #324 (permalink)
Old 02-26-2013, 06:06 PM
About 1 in. minimum, don't angle them!
Jester
  #325 (permalink)
Old 02-26-2013, 06:08 PM
the youngone
dont understand about 1 in soory
  #326 (permalink)
Old 02-26-2013, 06:15 PM
1 inch = 2.54 centimeter
  #327 (permalink)
Old 02-26-2013, 06:18 PM
the youngone
ooo and than concept 1 in alu or the plactic with tubes.. ? 1 inch thik plate or do you mean rhe tube lenght
  #328 (permalink)
Old 02-26-2013, 06:28 PM
A 1 inch plate with 4 venturi holes or a flat plate with 4 venturi 1 inch long down tubes both need to be a little bigger diameter then your carb throttle plates.
Jester
  #329 (permalink)
Old 02-26-2013, 06:32 PM
the youngone
ok this i going to be hard to explain in english but i try...
the thin plate has tubes .. they are going 1 inch INSIDE the manifold...the big plate is laying on the manifild .. right??? and wichone is better...
haha jester we l goning be there soon haha!
  #330 (permalink)
Old 02-26-2013, 06:55 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I'm not familiar w/using tubes down inside the intake, but I wouldn't want to put the ends of the tubes too close to the bottom of the intake. If the ends of the tubes are too close, the air/fuel mixture will get disrupted as it bounces off the floor. This is similar to a too small carb at high rpm- the flow cannot turn into the runners w/o hitting the bottom of the plenum.
All things considered, I think you'd be better off using a 4-hole spacer as thick as you have room for under the hood. But again- I have never used tubes.
Electric fuel pump, fan and water pump Curtis Thornton Electrical 9 05-08-2011 02:41 PM
Is it normal to have to pump the gas several times to get accelerator pump squirt ? fumplet Engine 3 11-16-2010 02:14 PM
Fuel Pump Pushrod/ Pump Mounting Plate (SBC) clicketyclack Engine 2 07-10-2010 12:08 PM
Electric fuel pump to manual pump engine.. RookieRodder Hotrodding Basics 7 02-14-2008 06:28 PM
Th-350 pump reassembly - position of gears and pump halves? Warrant Transmission - Rearend 1 06-02-2006 11:04 PM
