Pump them up? - Page 23 - Hot Rod Forum : Hotrodders Bulletin Board
  #331 (permalink)
Old 02-26-2013, 06:03 PM
the youngone
Last journal entry: progressthe
Its in a van ... With also a. Lpg mixer on top so i dont have the whole world of space haha. .. But now im looking at the performer manifold the dual plane chape is. Like 4 tubes but than 2 is 1 big hole
  #332 (permalink)
Old 02-26-2013, 06:04 PM
the youngone
Haha with a thick plate i also can fit a nos nozzle hahah :p
  #333 (permalink)
Old 02-26-2013, 06:09 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Actually, w/an LP setup you should be better off than you would be if using a carb because there's no problem w/atomization of the fuel.
  #334 (permalink)
Old 02-26-2013, 06:14 PM
the youngone
Ok but i also will run petrol.. Mostly ist better running than lp on a perfect setup right
  #335 (permalink)
Old 02-27-2013, 05:07 AM
the youngone
A friend of mine can cnc it out of trespa .. Good ?
  #336 (permalink)
Old 02-27-2013, 10:01 AM
painted jester's Avatar
TAKE A KID TO A CAR SHOW
Last journal entry: Wifes 79 comeing together!
I think the spacer with 4 holes would be best but I would try the intake as is! and and if you need the spacer add it later, The reversion plate should only come down 1/3 of the hight of the plenum max. The 1 inch measurement was from my memory. I ran that unit with a reversion plate years ago LOL ! But Wezz my memory may be wrong and the 1 inch tubes could be too long like Cobalt said.
Sorry Wezz I should have never mentioned the anti reversion plate on this thread!!! (velocity shear plate) Please disregard the anti reversion plate with your build
The reversion plate is usually made about 1/4 inch thick and if using 1 inch tubes the tubes would be actually 3/4 of an inch into the plenum. But must be tuned to a proper length for a max benefit (trial and error or a dino)! The reason I said 1 inch is because I thought I remembered the tuned length I ran with that intake and carter carb on a 283 years ago! (It popped into my head) And after Cobalt posted I had second thoughts on the tuned length
Wezz I don't think you will need either plate!!! Run the intake without one first!!!
I'll try to explain why I mentioned it to the others reading this!
I was just thinking that with the 305, and with that intake, that the anti reversion plate it could "kill 2 birds with one stone" A reversion bog, and broaden the rpm range of the intake to a little lower Rpm.
Anti reversion plates isolate the booster from pressure waves when the throttle is suddenly opened and the air moving down the venturis hits the turbulent air in the plenum like a "WALL" reversing the velocity creating a pulse that can (for a split second) actually force gas and air out the carb throat (called a BOG) before the intake flow and velocity catch up and smooth out! And at the same time broaden the power band a little like the upper spacer does!
The 4 hole spacer plates have RPM benefits below and above where the manifold is tuned. In other words, the engine has a small % broadened power band.
Jester
Im thinking now I shouldn't have posted this either Wezz I may be confuseing you LOL
  #337 (permalink)
Old 02-27-2013, 10:14 AM
the youngone
Confuzing is the right word on this yes .. Dont understand a word of wath uou sayd .. Mechanical english bleh ! Haha can you. Short explain .. What to do AFTER it runs like a dog without a plate..
  #338 (permalink)
Old 02-27-2013, 10:29 AM
I think it will run pretty fair without the plate, But if you need one run the upper spacer 4 hole plate! Im sorry I confused you! LOL
JesterLOL
  #339 (permalink)
Old 02-27-2013, 10:32 AM
the youngone
Drawing
Made a concept
  #340 (permalink)
Old 02-27-2013, 11:11 AM
http://www.hotrodders.com/forum/atta...1&d=1361988282
Wezz, you have a vacuum fitting in #8 intake port! That's not a good idea! If you get a vacuum leak it will lean that one (#8) cylinder, I would plug it and use the carb ports instead. And by no means use that #8 for a pcv port or it will damage # 8 cylinder!!!
Jester
  #341 (permalink)
Old 02-27-2013, 11:17 AM
the youngone
Ok i have A few vacuum recuires. Like the brake. Its goin on the back of the carb. I have the. Distributor An another thing .. Post a pic of it
  #342 (permalink)
Old 02-27-2013, 11:22 AM
the youngone
Dont have a pic. Its a big black. Tube. Wit a vacuum hose . And. 2 linea to onder te. Transmission. .. Any idea?
  #343 (permalink)
Old 02-27-2013, 12:50 PM
You need ported vacuum for the dist., manifold vac. for the PCV and trans. You can get your power brake booster off #8 but if there was a leak in the booster, or when you pump the pedal there is a fluctuation in #8 mixture that effects the running of that cylinder! I just put a solid plug in #8 port and don't use it!
Jester
  #344 (permalink)
Old 02-27-2013, 12:54 PM
the youngone
hii maybe you get sick of me but can you draw a litle or show me how to connect the brake etc how does the black tube calls ... i had a picture but its ghone..
  #345 (permalink)
Old 02-28-2013, 05:14 AM
the youngone
Good
Hi jester i found a adaptor .. In the netherlands .. Is rhis a good one ?
Electric fuel pump, fan and water pump Curtis Thornton Electrical 9 05-08-2011 01:41 PM
Is it normal to have to pump the gas several times to get accelerator pump squirt ? fumplet Engine 3 11-16-2010 01:14 PM
Fuel Pump Pushrod/ Pump Mounting Plate (SBC) clicketyclack Engine 2 07-10-2010 11:08 AM
Electric fuel pump to manual pump engine.. RookieRodder Hotrodding Basics 7 02-14-2008 05:28 PM
Th-350 pump reassembly - position of gears and pump halves? Warrant Transmission - Rearend 1 06-02-2006 10:04 PM
