Pump them up? - Page 29 - Hot Rod Forum : Hotrodders Bulletin Board
  #421 (permalink)
Old 04-18-2013, 01:32 AM
painted jester's Avatar
TAKE A KID TO A CAR SHOW
Last journal entry: Wifes 79 comeing together!
Originally Posted by painted jester View Post
I would run a good 10w30 engine oil with ZDDP or use a Zinc adative like LUCAS, your breaking in a new flat tappet cam YOU MUST use the zddp oil or a good break in oil like BARRY GRANT oil or equivalent
Jester
I typed Barry grant oil That was a miss type LOL I was talking that day about B.G. Products!!! What I meant to type was Joe Gibbs BR break in oil !! Sorry about that Wezz
Jester
  #422 (permalink)
Old 04-18-2013, 01:44 AM
the youngone
Last journal entry: progressthe
Ok but i dint have that oil i have braga 10w40 semy sentetic . Can i use that in combi with te lucas additive .. It says you can use it wit any regular oil ...
  #423 (permalink)
Old 04-18-2013, 01:49 AM
The Lucas additive tech sheet states that you add 1 bottle for break in and for every oil change after that and it treats 4.5 qts. or 4258.59 ML to 5,000 ppm Zddp!
Jester
  #424 (permalink)
Old 04-18-2013, 01:54 AM
the youngone
So after 500 miles i can change the oil and. Again. Put the. Lucas. Zddp in the oil .. Same assembly?
  #425 (permalink)
Old 04-18-2013, 01:59 AM
the youngone
I mean composition. From oil and lucas zddp
  #426 (permalink)
Old 04-18-2013, 02:01 AM
I don't know that oil Wezz "10w40 semy sentetic" and you said it was a mineral oil? I don't know I don't use synthetic or mineral oils except in rotary engines where it is recommended! I wouldn't use it in your engine! But I'm no expert on oils Maybe Vinnie or Cobalt , 1Gary, Fbird, techinspector etc can chime in on that and give you a definite answer!! I wouldn't guess on something that important !!!
Its 4:04 am LOL I have to get up in 3 HRs GNite Wezz
Jester
  #427 (permalink)
Old 04-18-2013, 02:07 AM
the youngone
The shop said it was. Mineral but i Chekked it and i saw its semi sentetic
  #428 (permalink)
Old 04-18-2013, 02:40 AM
1Gary's Avatar
Last journal entry: 383 dyno sym
Never use any kind of synthetic for flat tappet cam break-in.That decision would be one you would regret.
  #429 (permalink)
Old 04-18-2013, 02:52 AM
1Gary's Avatar
Wezz, you can mix it or add it in the valve cover either way, you have the break in lube already on the cam lobes and lifters and your priming the pump and oil galleys before you start the engine so you will be alright either way Its no big deal! Ive seen it done both ways and Ive done it both ways!!
Jester
We believe guys can and do over prime engines.It is a tip we picked up in the trades publications yrs ago.That in using a 1/2 drill motor you prime so the drill slows down twice.Once to fill the oil pump and once to fill the oil passages then stop.It helps in not washing out the all assembly lube.
  #430 (permalink)
Old 04-18-2013, 02:57 AM
the youngone
Ok . Then i go get. Oter oil . What kind and mark would you guys say .. And. Uh the sentetic oil is already in te engine. In the lifters oill filter etc just take the carter plug out? And put the right oil in it ??
  #431 (permalink)
Old 04-18-2013, 03:14 AM
the youngone
I already. Turned the engine over to let. Turning the waterpump ..
  #432 (permalink)
Old 04-18-2013, 06:10 AM
the youngone
Ok then i take 20w50 mineral + 75 cc of zddp from lucas .. Good?
  #433 (permalink)
Old 04-18-2013, 09:31 AM
the youngone
Look what i have ! But the techsheet says ad one full bottle with regular oil capacity of engine . ?? Thats not 75 cc right?
  #434 (permalink)
Old 04-18-2013, 09:34 AM
the youngone
Bottle
Look i have the bottle
  #435 (permalink)
Old 04-18-2013, 12:31 PM
Add the whole bottle of Lucas unless the oil you use has a high Zddp level already!
1gary is right and I agree , in my opinion, I would drain it out and change the filter, add good oil and the whole bottle of the Lucas mix it first seeing as you already primed and filled the oil pump and galleys with the synthetic!
Myself and 1gary may be incorrect on our assumptions about synthetics but we have our own views!
Wezz Motor cycle oils like used in Harley Davisons or BMWs have high zddp levels! see what the motorcycle guys are using!
Sufficient ZDDP in new or fresh flat tappet cam and lifter engines is absolutely CRITICAL!!
Wezz I talked to my nephew in Belgium, can you get Cen-pe-co Super Racing Oil where your at? it has 2400 parts per million zinc and 2200 ppm phosphate it would work fine for the half hour break in of the engine. and to run after Break in!
I talked to a classic MGB owner here , he uses Comma Premium oil or Comma Classic the Comma Premium is better for its extra ZDDP. can you get that there?
I know our language barrier is confusing to you (and it is aggravating LOL) There is a hot rod club in Holland They have a web site contact them!!! They will probably help you a lot!!!!
Jester
Cruizin Angles ~ Netherlands
Hi I am the starter of our American car club "Cruizin Angels” in the Netherlands. More and more American cars are running and each year over here. More and more meetings are organized, one meeting has already over 2,500 cars and more then 10,000 visitors, just wanted to let you know about our site.
Email: info@cruizinangels.nl
Website: Cruizin' Angels
Rhein-Main-Cruiser & Goodguys Member ~ Germany
German / American Car Club , started in 1979 with American Soldiers out of Rhein-Main Air Base and German US Car Freaks". Based around Frankfurt am Main. 85 Member who own 165 US-Cars. (Hot Rods, Customs, Muscle cars, Classics )
Email: rmc@gsra.de
Website: Goodguys Members Germany
German Street Rod Association ( G S R A ) ~ Germany
Since 1993. Pre 1949 Street Rods. 247 Members. 180 Street Rods on the road...
Website: GSRA •• German Street Rod Association
Jester
Electric fuel pump, fan and water pump Curtis Thornton Electrical 9 05-08-2011 01:41 PM
Is it normal to have to pump the gas several times to get accelerator pump squirt ? fumplet Engine 3 11-16-2010 01:14 PM
Fuel Pump Pushrod/ Pump Mounting Plate (SBC) clicketyclack Engine 2 07-10-2010 11:08 AM
Electric fuel pump to manual pump engine.. RookieRodder Hotrodding Basics 7 02-14-2008 05:28 PM
Th-350 pump reassembly - position of gears and pump halves? Warrant Transmission - Rearend 1 06-02-2006 10:04 PM
