Pump them up? - Page 31 - Hot Rod Forum : Hotrodders Bulletin Board
  #451 (permalink)
Old 04-18-2013, 10:56 PM
the youngone
Last journal entry: progressthe
I know haha jester always helps . Uhm here 7 on the morning
  #452 (permalink)
Old 04-18-2013, 11:25 PM
the youngone
Oh before i forgot The lifters are still full of syntetic oil .. Will it mix with the mineral oil. ?
  #453 (permalink)
Old 04-19-2013, 09:45 AM
the youngone
Oil
Look look what i have .! Is it good ? Can i put the. Lucas to the oil. Can so its already mixt ?
  #454 (permalink)
Old 04-19-2013, 12:57 PM
painted jester's Avatar
TAKE A KID TO A CAR SHOW
Last journal entry: Wifes 79 comeing together!
VR1 Racing Oil is just ordinary car street oil that says "Racing Oil" with a maximum street legal ZDDP level! But with the Lucas added it will be fine! So you will be good Wezz And yes you can Mix it.
According to Valvoline's website 2011, all weights of VR1 have .13/.14 % z/p. and Valvoline VV851 Racing 20W50 NOT STREET LEGAL Motor Oil is .14% of Zinc and .13% of Phosphorus. A little better!
But Blackstone Labs Oil Analysis:
Says VR1: has a Zinc level of .13% or 1300 PPM and .12% Phos. is 1200 PPM So its a bellow minimum level for flat tappet cams!
Blackstone Labs They will send you a test kit and you can have your crank case oil or new oil analyzed and know for sure (last time I had it done it was 25 dollars)
Jester
  #455 (permalink)
Old 04-19-2013, 01:01 PM
the youngone
So. Just ad the lucas in the 4.7liter oil good?
  #456 (permalink)
Old 04-19-2013, 04:24 PM
Yes!!!
Don't overfill the pan!!!
Jester
  #457 (permalink)
Old 04-19-2013, 07:07 PM
the youngone
I took the oil in the engine .. Inc the zinc afditive its 4.7 liters good right so im finnisht. . Engine can run
  #458 (permalink)
Old 04-19-2013, 08:17 PM
Yes
  #459 (permalink)
Old 04-21-2013, 03:20 PM
the youngone
Yes yes yes its alive haha I turned te key and it starts ! @ ones but the fuelpump relais is broken . So the engine stopes. Te fuelpump directly on a Battery. And.it runs for 25 minuutes + - about 2500 rpm.
But i have some questions. We had a stobe light And @800 rpm he had 8 degree and @ 4500 rpm it haves 45 degree .. Is that right. Oh its with the vacuum on the. Msd ignition .
And... I have @ 800 rpm 34 ps oilpressure. An @ 2000rpm 40-44 psi oil pressure . Is that good!?
  #460 (permalink)
Old 04-21-2013, 03:36 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You should not idle the engine until AFTER the cam has been broken in. If the timing was read after the cam was done breaking in, all's good. Not good if the engine was idled BEFORE the cam was broken in.
45 degrees at 4500 rpm is fine for break in.
More on setting up a performance timing curve is here.
  #461 (permalink)
Old 04-21-2013, 03:40 PM
the youngone
It was after haha i know it starts and i go to 2500 rpm for 25 minuutes . Afther that we did te timing .. How about the oil pressure??
  #462 (permalink)
Old 04-21-2013, 03:57 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
General rule of thumb is 10 psi per 1000 rpm. Example is 65 psi for an engine that turns 6500 rpm.
And congratulations!
  #463 (permalink)
Old 04-21-2013, 04:00 PM
the youngone
I dont think my engine. Makes 6500 haha. So do you think its okay or. Do i have to. Take a new pump ?
  #464 (permalink)
Old 04-22-2013, 01:11 PM
the youngone
Where is jester haha
  #465 (permalink)
Old 04-22-2013, 01:28 PM
I was at a visitation yesterday and the funeral this morning and tonight I have another visitation and a funeral tomorrow. and another on Wednesday ( 2 are family members and 1 a good friend ) so listen to Cobalt or Vinny Etc. Don't wait for me LOL! And congratulations on starting and breaking in the cam being successful! Gotta Go!!!!
Jester
Electric fuel pump, fan and water pump Curtis Thornton Electrical 9 05-08-2011 01:41 PM
Is it normal to have to pump the gas several times to get accelerator pump squirt ? fumplet Engine 3 11-16-2010 01:14 PM
Fuel Pump Pushrod/ Pump Mounting Plate (SBC) clicketyclack Engine 2 07-10-2010 11:08 AM
Electric fuel pump to manual pump engine.. RookieRodder Hotrodding Basics 7 02-14-2008 05:28 PM
Th-350 pump reassembly - position of gears and pump halves? Warrant Transmission - Rearend 1 06-02-2006 10:04 PM
