Pump them up? - Page 32 - Hot Rod Forum : Hotrodders Bulletin Board
  #466 (permalink)
Old 04-22-2013, 01:52 PM
the youngone
Last journal entry: progressthe
Haha want to know how i can chek or the cam is breaing in good .. And want to know. Hoe much degree the. Timing must be afrer the brakein .. So on the road
  #467 (permalink)
Old 04-22-2013, 03:43 PM
the youngone
another thing . my fuel pump was falling out after a few seconds. and i dont know where to search. it has a 12v plus if i turn the key but thats onle for a few seconds. so the pump pumps full the carb and stops..
i gues there are a few people befoe i had the van who did hobby on the wiring.. so i gues i have to make it myselve.
so the thing. when the car is empty the engione can not start .. i know they have savetyswitches to the distributor and if the relai sees the ignition. it gives power to the engine .. but when the engine is off we have no iginitial.. so how can i give the fuel pump power a few second and then start , so the relais sees the ignition.? somone any idea?
  #468 (permalink)
Old 04-29-2013, 07:20 PM
painted jester's Avatar
TAKE A KID TO A CAR SHOW
Last journal entry: Wifes 79 comeing together!
I'm sure you have the bugs worked out already?
Sorry Wezz! I haven't been on in a while LOL!! I thought someone would have helped you out
I would set the timing at 10 or 12 degrees before top dead center with vacuum advance disconnected and pluged off ( if you have a vacume advance??!!) as a starting point. Then hook up the vacuum advance and add a couple of degrees at a time and test run it till you get what you are comfortable with! If you advance it too far and it acts up back the timing off to where it ran good!
Jester
  #469 (permalink)
Old 04-30-2013, 02:53 AM
the youngone
We did it like u sayd . But. Now it haves @ 2500 rpm 45 degree.. It runs good i have a video but dont know how to send it . What do you think about 30psi ool pressure on idle and 40 psi @ cruising around ?
  #470 (permalink)
Old 04-30-2013, 12:17 PM
That's good oil pressure for your build and RPM range! !!
45 degrees total advance is high! for your rpm range! I might bring it down to about 34!
OK, I looked at the pic of the distributor you posted! It has a vacuum advance but I don't know if its adjustable or not? And did you change the centrifugal advance in any way, like adding weaker springs or lighter weights?
But then again If its running fine for you and starting fine, leave it alone LOL!
You can join Utube and post your video on Utube and then put them on here ( that's how my Daughters do it for me)!
Jester
  #471 (permalink)
Old 04-30-2013, 03:33 PM
the youngone
Hello
Ok i try to get a youtube movie. And uhm yes k think a friend of mine he. Changed somting in the hei distributor cap. And it runs verry wel. Thnx jester how can i thankyou haha
  #472 (permalink)
Old 04-30-2013, 04:05 PM
You just thanked me and the others that helped by continuing this thread to the finished product, its a great thread and the videos and pics your going to post will make it over the top
Jester
  #473 (permalink)
Old 04-30-2013, 04:08 PM
the youngone
Nice . I have. Some pics from the van I post them now . Judt. Wasching the van today
  #474 (permalink)
Old 04-30-2013, 04:10 PM
the youngone
Pics of the van
Comments are welcome
  #475 (permalink)
Old 04-30-2013, 04:12 PM
the youngone
Inside pic
Inside of the van
  #476 (permalink)
Old 04-30-2013, 04:14 PM
the youngone
Pic of the van
Side view of van
  #477 (permalink)
Old 04-30-2013, 04:16 PM
the youngone
Engine
View of engine. From inside
  #478 (permalink)
Old 04-30-2013, 04:17 PM
the youngone
Rims
This are my wheels
  #479 (permalink)
Old 04-30-2013, 04:18 PM
Nice looking Van Wezz All you need are a few girls in bikinis and a beach
Jester
  #480 (permalink)
Old 04-30-2013, 04:19 PM
the youngone
Haha sorry cant show the girl haha
Electric fuel pump, fan and water pump Curtis Thornton Electrical 9 05-08-2011 01:41 PM
Is it normal to have to pump the gas several times to get accelerator pump squirt ? fumplet Engine 3 11-16-2010 01:14 PM
Fuel Pump Pushrod/ Pump Mounting Plate (SBC) clicketyclack Engine 2 07-10-2010 11:08 AM
Electric fuel pump to manual pump engine.. RookieRodder Hotrodding Basics 7 02-14-2008 05:28 PM
Th-350 pump reassembly - position of gears and pump halves? Warrant Transmission - Rearend 1 06-02-2006 10:04 PM
