Pump them up? - Page 6 - Hot Rod Forum : Hotrodders Bulletin Board
  #76 (permalink)
Old 02-04-2013, 12:10 AM
the youngone
Last journal entry: progressthe
Haha so actualy no one knows the perfect lenght for mu setup . Can anyone show me pics from good setup pushrods an a pic how it is in a bad situation. Where malc was talking about
  #77 (permalink)
Old 02-04-2013, 12:23 AM
painted jester's Avatar
Last journal entry: 383 BLAH, BLAH.
Wezz Check out #4 and read the whole article!
You can buy a push rod length checker
Jester
  #78 (permalink)
Old 02-04-2013, 12:55 AM
the youngone
I know .. And you i cam make one with a old pushrod . But i dont know how it looks like its the right lenght
  #79 (permalink)
Old 02-04-2013, 12:57 AM
I looked every where for an easy way to check for you! With this video, you and that tool, you can check if your push rod length is right or not!! Its very easy!
myvintageiron7512: How to check for correct rocker arm geometry : when building any engine rocker
This is the push rod length checker pic! It didn't load on the first post! LOL Its very easy to use!
Proform Parts 66789 - Proform Pushrod Length Checkers
  #80 (permalink)
Old 02-04-2013, 01:00 AM
the youngone
O okay but i think they dont have one of these here in holland haha i think i am buy. The 7.8 and drive it
  #81 (permalink)
Old 02-04-2013, 01:11 AM
the youngone
But can edelbrock tell me. Te right lenght u think?
  #82 (permalink)
Old 02-04-2013, 01:24 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
What heads are you using?
Have the decks been milled?
What rocker arms are you using?
Has the rocker stud boss been machined?
What length valves are you using?
Is the base circle of the cam reduced?
Has the block been milled?
What is the quench distance?
  #83 (permalink)
Old 02-04-2013, 01:26 AM
malc's Avatar
Born To Be Mild
Originally Posted by painted jester View Post
Hey Malc
Drive over and give him a hand your closer then me LOL
Jester
At least a twenty four hour drive.
  #84 (permalink)
Old 02-04-2013, 01:27 AM
Yes Comp. probably can , Malc is probably right with the 7.8 and comp can probably send you that tool too! Or order the tool from Summit!
Jester
  #85 (permalink)
Old 02-04-2013, 01:30 AM
malc's Avatar
Born To Be Mild
Wezz, do you have any pushrods at hand stock or otherwise,
just to get some kind of starting point ?
CompCams pushrod tech.
  #86 (permalink)
Old 02-04-2013, 01:31 AM
Yea
Its 3:30 am Here Good night Guy's!
Jester
  #87 (permalink)
Old 02-04-2013, 01:35 AM
Jester
Man I See this didn't post complete
Thanks malc you posted the same tech article that I tried to
Night All!
  #88 (permalink)
Old 02-04-2013, 01:39 AM
the youngone
Stock 187 head decks are miller . Underblock dont stock valves stock rockerarms . Studs are not been mahined inhave new valve seat in exhaust and the intake is regrinded valves are regrind ... Quincendistance and base circle i dont understand
  #89 (permalink)
Old 02-04-2013, 01:50 AM
malc's Avatar
Born To Be Mild
If you have a stock length pushrod, install it correctly and watch it as you turn the motor.
Squish, Quench, and Piston-to-Head Clearance
Quench area, on the left, piston to head clearance.
There´s enough information here to sink a ship....
  #90 (permalink)
Old 02-04-2013, 02:00 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Stock length pushrods are going to be very close.
Electric fuel pump, fan and water pump Curtis Thornton Electrical 9 05-08-2011 01:41 PM
Is it normal to have to pump the gas several times to get accelerator pump squirt ? fumplet Engine 3 11-16-2010 01:14 PM
Fuel Pump Pushrod/ Pump Mounting Plate (SBC) clicketyclack Engine 2 07-10-2010 11:08 AM
Electric fuel pump to manual pump engine.. RookieRodder Hotrodding Basics 7 02-14-2008 05:28 PM
Th-350 pump reassembly - position of gears and pump halves? Warrant Transmission - Rearend 1 06-02-2006 10:04 PM
