Pump them up? - Page 7 - Hot Rod Forum : Hotrodders Bulletin Board
  #91 (permalink)
Old 02-04-2013, 02:10 AM
the youngone
Last journal entry: progressthe
The stock pushrod is way to short i can put the pushrod realy up and down. Like u see in the picture i post earlyer in the topic
  #92 (permalink)
Old 02-04-2013, 02:14 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Stock flat tappet pushrods (7.8")- not the OEM roller cam p-rods.
  #93 (permalink)
Old 02-04-2013, 02:18 AM
the youngone
Okey sorry i read it wrong. So you say. 7.8 is going to be verry close . But what if i messure them and i see its a little to ling or to short . Are there. Longer rods ten? Thanx guys realy happy with your helping hands
  #94 (permalink)
Old 02-04-2013, 02:28 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
For the SBC engine, there are "off the shelf" pushrods in any length you might need. They come in 0.050" increments.
  #95 (permalink)
Old 02-04-2013, 03:46 AM
the youngone
Oke. Uhm and about the timing gear. Kit ..
my chain is not very tight there is some play on is that normal?
  #96 (permalink)
Old 02-04-2013, 04:21 AM
malc's Avatar
Living At The Speed Of Life
Here is a snapshot of my number one cylinder (@ TDC) exhaust roller rocker,
taken today.
My block is a stock roller cam block, the heads are Brodix IK200, head gasket
Clevite, CLE-5746, compressed height 0.026.
The pushrod is stock length and you can see the roller tip is just inboard of the valve stem centerline.
Maybe I was just lucky but stock length seems a good place to start.
Wezz The stock pushrod is way to short I can push the pushrod realy up and down. Like u see in the picture i post earlier in the topic
Have you adjusted it correctly ?
  #97 (permalink)
Old 02-04-2013, 04:26 AM
malc's Avatar
BTW, I installed new lifters about one year ago,
didīnt pump them or soak them in oil.
Just applied the break in lube supplied with them.
  #98 (permalink)
Old 02-04-2013, 04:45 AM
the youngone
I did not even tightened the bolt so you could already see that the countries did not make it .. but I now flattapped lifters and a roller pushrod
  #99 (permalink)
Old 02-04-2013, 07:59 AM
the youngone
Pushrod and timing chain
And how tight needs the timing chain to be?
  #100 (permalink)
Old 02-04-2013, 08:59 AM
malc's Avatar
Is it new, if yes....tight, no slack.
You are not going to get any further until you get a stock pushrod
to get started, at least to see where you are.
I think you were told earlier a roller pushrod is not going to be right.
The other way is to buy an adjustable pushrod which will find the right length for you to use.
Then go to SummitRacing and look for a set of pushrods of that length.
Pushrod search at Summit.
cobalt327
  #101 (permalink)
Old 02-04-2013, 09:06 AM
the youngone
Thats stange my brand new timing gear has a little slack But that timing gear has to be good with a edelbrock 3702 cam ??
  #102 (permalink)
Old 02-04-2013, 10:14 AM
malc's Avatar
At 10:00 he shows "tightness" of the chain.
Is yours the same ?
  #103 (permalink)
Old 02-04-2013, 10:31 AM
malc's Avatar
Honestly i am in clas 1. Becouse here in holland they dont know so much as you guys in the us . I am a welder no mecanic or what else . My hobby is my van i want to learn things over a v8 engine. But in holland its diffucult to. See a person. Who has the know of the engines like you . So i ask (whit the best english i can) To you guys how to do it.i get a paper from edelbrock. Which says do not pump them up. I was looking on the web what pumping up means. And i found out there are people says yes do it end people no do it not .
I think you should search out someone who can help.
There are many hotrodders in Holland.
Where do you live in Holland ?
  #104 (permalink)
Old 02-04-2013, 10:38 AM
the youngone
No mine is the cloyes c 3055 its a singel gear set and uhm no i think i understand what i have to do i am buying that tool and i alread have a longer pushrod from a friend. 7.8" and if its fit well i take the hole set otherwise i am order a larger one but the timing chain i dont understand te slack
  #105 (permalink)
Old 02-04-2013, 10:40 AM
malc's Avatar
Watch the video I posted, the man checks the tightness or slack whatever you want to call it.
See what he does then do the same to yours.
Electric fuel pump, fan and water pump Curtis Thornton Electrical 9 05-08-2011 01:41 PM
Is it normal to have to pump the gas several times to get accelerator pump squirt ? fumplet Engine 3 11-16-2010 01:14 PM
Fuel Pump Pushrod/ Pump Mounting Plate (SBC) clicketyclack Engine 2 07-10-2010 11:08 AM
Electric fuel pump to manual pump engine.. RookieRodder Hotrodding Basics 7 02-14-2008 05:28 PM
Th-350 pump reassembly - position of gears and pump halves? Warrant Transmission - Rearend 1 06-02-2006 10:04 PM
