Here are a couple of websites in Holland, LILYPADSPEEDSHOP and
Perry´sRodShop. Try contacting either one to get more local help. |
There ya go! Horsepower is alive and well in Holland, looks like.
Just got back! Sorry Wezz, they closed I didn't make it in time
I'll go back in the morning! If you still need it? I read the last few posts, I see there may be help in Holland for you!Jester You guys see those Holland videos? 02112008077.mp4 Video by hershamboy1960 | Photobucket Last edited by painted jester; 02-04-2013 at 04:43 PM. |
thnx jester il still need it .. becouse i already know what they wil say is i cal one of those shops .. o yeah we have to order it . i m waiting always so long for the shipping so thanx jester iil wait for you to go to the shop
ps the video i have is a mpeg or somthig like that so not a utube video and i dnt have a utube acount also i have made a few pics i saw the machine shop has grinded the tip of the valvestem too.. good news? and oyeah i hold the rockerarm like it has to on the upcoming pic .. right?
pics
here the pics also 1 from my block
The small amount that's removed from the tip of the valve won't hurt anything. It more or less offsets the valve seat in the head being a bit deeper and the valve's seat a bit thinner when the valve job was done. So the overall difference equals out. More or less.
![]() I see you have exhaust valve rotators on the heads. Shouldn't be a problem with the springs the cam you have calls for. |
At least call your supplier and see if they can get it and how long it will take and let me know! If you really need my help or not? you may be able to get it before me LOL. Was your machine work done by a shop close to you????? Jester |
| The Following User Says Thank You to painted jester For This Useful Post: | ||
PatM (02-04-2013) | ||
@ painted jester No its not to far from
Here and thnx i will cal a few shops today maybe thay have a tester @ cobalt i understand the story about the valves Min and more wil catch eachother up. .but the story about the spring is not clear for me jet .
I get parts from Summit delivered by iparcel in a week.
With iparcel your shipping and taxes are paid when you submit your order. I was thinking that you could call those people in Holland and get advise in your language. Or you could sign up here Rod´nSods.co.uk and I´ll get you in contact with a rodder in Holland. |
But you guys are helping me out already so dont need the people in holland haha
In engines that will see high rpm these rotators are removed and replaced with retainers like are on the intake valves. But with your cam, you don't need to worry about this. Are the springs stock? Not to bring up something else to worry about, but it is always better to replace the stock springs with new springs recommended for the cam you're using. I apologize if this has already been covered. Has the valve spring installed height been verified? |
Hi yes they are stock springs But there is a spring inside the spring .. Is that normal? Btw they say on the edelbrockweb its also good enough to usr stock springs. With te performer plus.
From Valve Spring Installation - Mopar Muscle Magazine ![]() "At the bottom we have a typical single spring with damper, actually a factory 440 Magnum piece. This is not to be confused with a dual spring, above, which carries another true inner spring in addition to the main spring, and usually a damper." |
Okay so the lower is better but not needed for me?
The dual spring is not needed, a dual spring is for a BIG camshaft.
| Electric fuel pump, fan and water pump | Curtis Thornton | Electrical | 9 | 05-08-2011 01:41 PM |
| Is it normal to have to pump the gas several times to get accelerator pump squirt ? | fumplet | Engine | 3 | 11-16-2010 01:14 PM |
| Fuel Pump Pushrod/ Pump Mounting Plate (SBC) | clicketyclack | Engine | 2 | 07-10-2010 11:08 AM |
| Electric fuel pump to manual pump engine.. | RookieRodder | Hotrodding Basics | 7 | 02-14-2008 05:28 PM |
| Th-350 pump reassembly - position of gears and pump halves? | Warrant | Transmission - Rearend | 1 | 06-02-2006 10:04 PM |
