Pump them up? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-30-2013, 11:46 PM
the youngone
Last journal entry: progressthe
Pump them up?
Hi. Yesterday my new cam and lifters. Were dilivered But now im dnt know if i have to pump them up or put them in a container with oil. The edelbrock says no but a lot of people are saying yes . So what to do .. Thnx
Old 01-30-2013, 11:49 PM
S10 Racer's Avatar
http://www.warsprints.com
Soak them in oil but do not pump them up.
Old 01-31-2013, 12:05 AM
vinniekq2's Avatar
use a solid lifter cam instead
Old 01-31-2013, 12:08 AM
the youngone
Lifter
So for how long do they have to soak in the oil .. Btw its the performerplus cam and lifterkit
Old 01-31-2013, 12:23 AM
painted jester's Avatar
Last journal entry: 383 BLAH, BLAH.
They don't need to soak (makes a big mess) just coat with oil and put break in lube on the bottoms and install!
Jester
Old 01-31-2013, 12:28 AM
LOL We just got off a thread like this LOL Im going to quit answering the same questions over and over Vinnie! Your answer is a good one on these questions!!!!! It made me laugh!!!!!
Jester
Old 01-31-2013, 12:32 AM
the youngone
I use a hydroulic lifter that came with the cam kit
Old 01-31-2013, 12:44 AM
Wezz:
This is what I posted on another thread about pumping up lifters:
Jester
Cleaning , and proper lubricating is a much better use of your time. There are so many installers who don't do that most important step CLEANING!!
Soaking in a can of oil is messy and wont fill a lifter only the small cavity above the plunger & below the pushrod seat! you must compress the lifter till it bottoms out and release it to fill it while under the oil in the can, or tear it down fill and reassemble it for those of you that want to fill yours
Bleed down rates vary by design if heavy break in lube or small debree enters the lifter with a slow bleed down rate it can lock the lifter and it wont bleed down! That's why you don't use anything but oil on the lifter bores or the sides of the lifters! Over the years Ive seen them locked up right out of the box and had to tear down and clean them or get a replacement, and some that wont pump up! cheap brands like Su----, J--s, Cr-w, etc Maybe a dozen over 50 years installing cams kits or new lifters!
The last word from me on this is if a tech sheet said don't pump up a lifter I wouldn't say "Hell I'm going to pump it up anyway"! Nor would I say "Hell I'm going to break in my cam at 4000 rpm for 15 min" if a tech sheet say's 2000 for 1/2 hr. because some people say that's all that's needed or wrote a paper on it ,or you watched u tube and saw some videos of people doing it and the car still runs at the end of their home made video
Old 01-31-2013, 01:19 AM
the youngone
But what is it what edelbrock talks about. Bent pushrods and valves. ? By pumping
Old 01-31-2013, 01:56 AM
Follow Edelbrocks instructions or don't your going to get answers on both sides of the question If you think the people who say pump em up are right and all the people who say don't plus Edelbrock, VooDoo, Crane, Howards, ETC, who engeneered and designed the product are wrong!! Do as you wish!
Its your engine
Jester
Do your tech sheets read different then this? Do they say pump them up?
Edelbrock Corp.
INSTALLATION INSTRUCTIONS
1. Coat cam lobes and bottom of each lifter with MOS2 lube supplied
with your kit. This will prevent cam lobe and lifter
wear from occurring during initial engine start up. Do NOT
pre-oil or "pump-up" lifters before installation as this may
hold valves off the valve seat leading to loss of compression
and/or bent valves during initial engine start up.
Old 01-31-2013, 02:06 AM
the youngone
Ok but how to adjust the rocker nut with a empty valve lifter?
Old 01-31-2013, 02:35 AM
There are a couple of lifter that are pumped up before installation usually ant pump 0 lash types and Rhoads lifters! So a person needs to read directions!
Jester
HOW TO's: ORIGINAL RHOADS LIFTERS
Before installation, each Rhoads Lifter should be fully filled with oil. To fill with oil, completely submerge each lifter upright into a container of oil and compress the inner plunger with a pushrod or screwdriver until the plunger is driven to the bottom of the lifter. Hold several seconds and release slowly. Repeat several times until the lifter is fully filled. NOTE: Soaking lifters in oil will not fill them. Also, make sure to apply assembly lube to each cam lobe and lifter bottom!
To understand and adjust your lifters go here:
http://www.crankshaftcoalition.com/w...raulic_lifters
Good night Wezz its 4:30 A.M. here!!!
Old 01-31-2013, 02:46 AM
the youngone
Im a little confused right now. So the question again . Do you recomend pump up the edelbrock lifters. Yes or no? Thanks
Old 01-31-2013, 04:08 AM
gearheadslife's Avatar
MentalMuffinMan
why are you not doing as the MAKER OF THE KIT says..
they've done the R&D they know what works and what doesn't.. with their gear.. either follow what they say or.. don't call them when your engine/cam fails..
#1 reason for cam failures.. installers that think some web guy knows more than the company that spent many r&d hours on their parts..
unless it was a top name builder telling you different than edel.
and you are on first name basic with him/her..
follow the directions surplied with your kit.. if you lost them edel will gladly email you them if they are not on their web site already...
good luck.. did you degreee the cam.. or just going to stab it in..
Old 01-31-2013, 04:37 AM
the youngone
Ok thanx bit what do u mean . Did you degree the cam or just going to stab in it
Electric fuel pump, fan and water pump Curtis Thornton Electrical 9 05-08-2011 01:41 PM
Is it normal to have to pump the gas several times to get accelerator pump squirt ? fumplet Engine 3 11-16-2010 01:14 PM
Fuel Pump Pushrod/ Pump Mounting Plate (SBC) clicketyclack Engine 2 07-10-2010 11:08 AM
Electric fuel pump to manual pump engine.. RookieRodder Hotrodding Basics 7 02-14-2008 05:28 PM
Th-350 pump reassembly - position of gears and pump halves? Warrant Transmission - Rearend 1 06-02-2006 10:04 PM
