Purple Hornies Anybody? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-24-2009, 07:26 PM
chewyscool's Avatar
Big Block 454
May be a dumb question but, inside the tube, the perferations only are open from one side? Are these reversable? My truck has a similar set with the perferations open to the rear of the exhaust and that is the only way that they could be installed. Does the sound just bounce around in the tubes entering from any direction? It would seem to me that the perferations should face the engine as to absourb some of the exhaust? Is this right?
(most of the time )
Old 07-24-2009, 09:40 PM
BOBCRMAN@aol.com's Avatar
The perforations just let the sound/pressure waves expand into the outer chamber. The tone of the muffler can be changed by the number and placement of the slots or perforations.
Old 07-27-2009, 08:09 PM
If the openings are facing the engine, you'll get a little less noise, and flow will be reduced. Facing the outlet, more noise and more flow. Either way, it won't flow as well as a muffler with flush holes in an equally-sized inner flow tube.
Old 07-28-2009, 07:54 PM
chewyscool's Avatar
Big Block 454
I got them on my truck this past weekend. They quieted down the drone of the exhaust I put on it 2 months ago. I used the same system I bought 10 years ago HeartThorb, but this time for some reason I got a terrible drone at crusing speeds. I'm happy with the final result, and thanks for the posts.
So you think royal purple is THE oil! dawg Engine 62 11-20-2013 06:05 PM
how loud are purple hornies? spinn Engine 4 06-30-2008 04:02 PM
purple hornies?? MuscleCarKid_1991 Engine 15 05-05-2008 07:15 PM
18 vs 32 inch purple hornies elcaminodragster Engine 65 07-13-2007 02:07 PM
Purple Hornies Glass Packs!!! fsiramps Engine 2 10-08-2003 10:40 PM
