Push Button Start - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-08-2009, 09:40 PM
Push Button Start
So the electrical bug bit me, as did the safety bug.
I've relocated the battery to the trunk with a disconnect switch, installed an inline fuel lock solenoid, hood locks and a Grant security system. So far, so good.
Now, I'd like to use a hidden push button start switch as well as an ignition kill switch while still retaining the use of my ignition key.
Here is what I have in mind; flip a toggle switch, turn the key in the ignition all the way, and then finally use my push button to turn the car on.
I already have a 50amp toggle switch and a 60amp push button starter switch.
How would I go about this?
Is it as simple as splicing the toggle switch into the wire that goes to the keyed switch, and then splicing the push button into the wire that goes from the keyed ignition to the starter?
Would I need to use a relay of some sort?
The car in question is a 1976 Ford Granada, if that helps any.
Old 09-08-2009, 09:47 PM
302 Z28's Avatar
What pray tell do you have invested in that 76 Ford Granada that warrants such technology?
Vince
Old 09-08-2009, 09:50 PM
Bad neighborhood + pretty car = trouble
"Basic of Basics" Welding - How do I repair body panels? Centerline Body - Exterior 29 06-18-2009 06:54 AM
push button start help, Chevelle malibu68 Electrical 6 04-12-2009 08:51 PM
Cam button length/clearance..? mrdreex Engine 1 04-12-2008 10:17 PM
87 Bronco doesn't start kgm656 Engine 2 05-30-2006 02:00 AM
start button wiring camod2 Electrical 3 06-23-2003 11:53 PM
