,push or pull ??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-25-2005, 04:43 PM
70Shorty's Avatar
Bob
,push or pull ???
I am installing a electric fan,,
which is better, the fan engine side pushing or grill side pulling ???
or engine side pulling or grill side pushing ???
I would like to see it grill side,,
what do the experienced ones say,,,
Thanks Bob,,
Old 05-25-2005, 07:02 PM
302 Z28's Avatar
Fan in front of the radiator pushing air toward the engine.
Vince
I stand corrected , it is better behind the rad pulling. Don't know what I was thinking.
Vince
Old 05-25-2005, 07:49 PM
AngliaBob's Avatar
It just takes time and money
Last journal entry: Specifications
Bob,
Check the manufacturers specs on the fan. Most of the fans have a better CFM rating in "Pull' over "Push". I have a 2950 cfm Pull, mounted engine side of radiator, with a shroud. I have a 1900 cfm Push, infront of my radiator/condenser, which I use with the A/C or as a supplement.
Good Luck,
Bob
Old 05-26-2005, 01:14 PM
70Shorty's Avatar
Bob
Hey thanks Bob,
The cfm is rated as 2450, I did read somewhere that pulling is better. I 'm rethinking as where to mount it, It will be fine inside engine compartment.
Thanks again, I really like this sight,,
Bob,,
Old 05-26-2005, 01:21 PM
1931 steve's Avatar
Last wiki edit: How to rebuild an engine Last photo:
Wiki Edits: 4
Thanks Bob,,
IMO I think it's better to have it in the engine bay between the water pump and the radiator, pulling air through the radiator. Use a fan shroud if you can. I believe this is the most efficient way for a fan to work. (in most cases)
Steve
Old 05-26-2005, 04:39 PM
docvette's Avatar
Wiki Edits: 12
Fan
Doc here,
Mounted in the Engine Bay, Pulling air thought the Radiator..on to the engine.
Is not only The Best way, But the Way MOST Stock locations are mounted.
SOME of the pluses are,
  • Better Cooling through the Radiator, From cool ambient air,
    More rigid Air stream on the Block and to evacuate the engine bay of static heat,
  • Doesn't Tend to "Block" or break up air flow in "Off" or "Inop" Conditions through the radiator,
  • Road "Fodder" (like plastic bags..ect..) Is least likely to become trapped in the blades.
Just my humble opinion..
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 05-27-2005, 01:25 PM
70Shorty's Avatar
Bob
Thanks guys,
I'll be mounting the fan inside,, Looks like the majority has it there,
Cool, no pun intended..
Bob,,
Poll : Push vs Pull skeeveman Engine 4 05-27-2005 04:06 PM
Caliper hanging causing pull while braking RAW Suspension - Brakes - Steering 4 07-12-2004 10:24 PM
Alignment problem 85 SS Suspension - Brakes - Steering 4 12-22-2003 03:02 PM
wiring before engine pull? flamedfordbronco Engine 8 12-19-2003 10:19 AM
camshafts....... pull the motor? Thacolbster Engine 3 01-27-2003 01:47 AM
