push rod??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-29-2011, 12:53 PM
push rod???
I Bought a 68 ford 302 engine that was in a dragster at one time.it has been removed and was taken down to the short block stage.my question is....
The block is a 302 but the heads that came with it are 289 heads.no push rods...do i buy 302 push rods that are longer or do i use 289 push rods that are shorter? im going with HYD.lifters
Old 03-29-2011, 01:07 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Looks to me like with the 289 heads on your 302 the blocks should be the same either way, IMO you would need the push-rods for the 289 heads to work out properly visa versa. JMO
Cole
push rod help 69camaro0 Engine 2 11-11-2009 10:20 AM
push rod que 39chevy Engine 2 07-30-2006 04:41 PM
push rod help please dyno340 Engine 2 04-03-2006 06:11 PM
push rod length rockurrolla Engine 6 01-22-2006 08:49 AM
I need help with push rods BinderRod1939 Engine 1 08-05-2004 09:09 PM
