push rod help please - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-03-2006, 04:14 PM
Hi,I have a 340 cu.in mopar with w2 heads,it is a total roller motor but I can't ge4t the push rods to stop bending or to keep them from rubbing on the walls of the heads. HELP PLEASE
Old 04-03-2006, 05:47 PM
NorthStar's Avatar
I think the W2 head requires a special offset rocker arm made just for those heads.
Old 04-03-2006, 06:11 PM
jim..'s Avatar
That 6 Cylinder Guy
Pushrods are available in any length/diameter/hardness/ends,that you need,just get an adjustable measuring push rod and figure out exactly what you need,then order them from crane,they are very helpful and fast.
Did you change anything on the motor,lifters,cam,rockers,valves,springs,etc.,thes e can change pushrod requirements.
I changed cam,rockers,and lifters and had to go to longer pushrods as well as hardened and double walled with guide plates.
383 vs 350 TheCiscoKid Engine 86 05-03-2008 03:10 PM
2 new forums: Hot Rod Art and Off-Topic Jon Hotrodders' Lounge 2 09-23-2005 03:50 PM
backfire teds 46 Engine 3 09-11-2004 07:20 PM
Push Rod Length? Rockers? bjam2 Engine 5 09-07-2004 12:12 PM
push rod prices chevypunk Engine 6 04-18-2003 03:55 PM
