Push rod lenght
Yeah , Ok 2 basic types of aftermarket Push rod,s ! Chromoly <<< Touted as being the Blank ! << Personally, I hate um ! Then Think there called Mitche Or Michele . <, Cant remember But think there Mitchel what I use . << My machinist just hand's um too me ??? Ive Never seen the Box .
But this is what I use on Vw motor's Mitchel Aluminum Push rodd's . Same ones used By V8 Builders . There Aluminum , And Expensive . But much easier too work with than Chromoly . Now On V8 Motors . << Havent Built one in 15 Year's ? It's been a while ? But Valve Geometry comes intoo play here . Push rodd lenght's are determined by Valve Geometry . << determines the Lenght . Way I do it is I build an Adjustable Push rod . << Get an approximate Lenght, then Cut tipp off a stock Push rod , Thread it with a Tapp . Then use a Bolt with a Modified head << That duplicate's a Push rod End , Then a Locking Nut ! Thread Nut on the bolt . Then screw bolt intoo the threaded end of the modified stock Push rod . Via adjustable Push rod, with locking nut ! Use Adjustable Push rodd too Get your valve Geometry , correct ! When Valve geometry is correct using the adjustable Push rod . You lock the Nut on it . << Push rod Lenght ! Basically on Vw motor ! I turn the motor over until the Valve spring is 1/2 way thru it's travel . << Have too determine when spring is compressed Exactly at 1/2 way . Then I look at the Valve tipp adjuster <<< Should be in a direct straight line with Valve stem . << Way Vw valve geometry is aquired ? >>> On V8's ??? I dont know ! Hydraulic Lifters ? I dont know ? But do know this ! I would find out . Valve geometry is important ! <<< Difference atween Good motor and a Badd motor ! Not a Guessin game ? Aftermarkrt head's, Valves, Rocker's, the Decking And Surfaceing , Of Block and Heads all affect what lenght your Push rod's need too be too Aquire a Proper valve geometry . Now on Actually Cutting Aluminum Mitchel Rodd's << Expensive and it's a One shot Deal . You mess um up ! It's over , Buy new sett ! <<, Easier too work with than Chromoly ? But I hate Chromoly Push Rods ! Far as im concerned, chromoly is Only good for Full on Race motor's , Runnin Fuel ! Napa has Book on V8 Chevy rebuild's << Probably has Section on Valve Geometry . There like 20 Buck's I would buy one ? Well worth the money ! Considerin money that goes intoo Rebuildin a Motor ? Post again with what Type of Push rod your Gonna be Usin ? << This will determine how I cut them Too lenght . I can Go over how I cut mine, if you like ? Sean |
![]() Click here for the translation. |
A low-buck way to get it right is to buy one of those $12 length checkers that fits on the rocker stud and then use a small pice of threaded rod/nut stuffed in the end of a stock push rod with the end cut off. You can then order the length you need. Bill
Push rod lenght
There You Go 71c10 ! Super Cool ! What you needed ! Translation from German too English ? Or is that American ?
But Super cool ! lott of People put a motor together , spend no time on Valve geometry ! Stock Motor you might get away with usin stock push rodd's ??? But this is where You Slow down , Get thing's Right ! Dig in and Study on it Some . Result's are well worth it ! Thank's ! I enjoyed Readin it ! V8's are Lil different than what Im use too ! Im still workin on figurin out a v8 build ! lookin hard at A Willy's Jeep Truck sittin in these peoples Yard , 2 Flatt tires! Then again Im still lookin Around . P.s. Got ant Url's for degreeing Camm's in V8 Motor's ? Sean |
| Proper way to get push rod length | Sparky06 | Engine | 4 | 02-04-2007 09:42 AM |
| '96 vortec 454 push rod broken after head job | LYNN MYERS | Engine | 4 | 10-22-2006 09:50 PM |
| Push Rod Length for this SBC? | 79 Malibu327 | Engine | 19 | 01-26-2005 06:30 AM |
| Rod Length | papabird | Engine | 0 | 07-07-2003 09:50 PM |
| push rod prices | chevypunk | Engine | 6 | 04-18-2003 03:55 PM |
