-   -   push rod length (http://www.hotrodders.com/forum/push-rod-length-168463.html)
crane359 11-14-2009 07:54 PM
push rod length
i am rebuilding a sbc 350 and im installing 1.6 roller rockers what is the correct length of pushrod to use, the heads are stock other than that.
can i use the stock push rods or do i need a new set?
DoubleVision 11-14-2009 08:14 PM
If you didn`t do anything to alter them such as mill the heads or block then stock lenth is fine.
