Push Rod Length Pontiac 400? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-18-2010, 10:33 AM
I am getting ready to swap heads and cam on my 75 Pontiac 400.
Old Parts:
head 6x-8, stock Pontiac cam, stock hydraulic tappet Pontiac lifters, stock Pontiac head gasket thickness.
New
head 6x-4 milled .040", Summit 2802 cam , Summit hydraulic tappet lifters, head gasket thickness .039
Can I use the stock push rods or do I need shorter ones?
I am using the stock rocker arms. Are these considered adjustable? Is there any thing I should be aware of using stock rocker arms?
Thanks
BT
Old 06-18-2010, 07:11 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Old Parts:
New
The heads have a "net lash" adjustment- they are not adjustable, per se. The nut is tightened to 20 ft/lbs (IIRC) against the shoulder of the "bottle neck" stud. The stud has a larger shank than the threaded portion on the top, so the nut won't allow for adjustment, as it comes stock- the nuts are not lock nuts.
As to whether or not you need different length p-rods, you'll have to mock up the engine and valvetrain, install the standard p-rods and see how much (if any) lifter preload you get w/the nut torqued down. If too much, shorter p-rods, if too little, longer.
That said, there are studs that replace the stockers that will allow adjustment using lock nuts or polylocks. Polylocks sometimes interfere w/the valve cover, so you'll have to check to see.
need help for push rod length for big block chevy bryant740 Engine 3 04-12-2010 04:47 PM
Measuring for push rod length is driving me crazy TNshadetree Engine 13 03-05-2010 01:34 PM
fuel pump installation wiser626 Engine 8 05-18-2009 09:44 PM
Push rod length sgo70 Engine 3 09-13-2008 07:43 PM
Push Rod Wall Thickness - BBC leejoy Engine 1 03-18-2008 10:18 AM
