by David Vizard Bogie |
Re:- Push rod pinch
The reason I am asking about port area is I'm looking to get 50 hp out of my 652cc single. My carb is 42mm at inlet and exit and 41mm at the venturi, inlet port is round and 42mm diameter leading to two 37mm valves, Exhaust valves are 2x32mm, the pipe is 41.3 i.d. leading into a big glasspack approx 2" i.d.
With a dynojet kit with std filter, carb and pipe she was making 40.5 hp the needle in the std 40mm CV carb and the 41mm slide carb I have now are about the same but the CV had a 4.3mm thick butterfly spindle which has to be a major restriction also silencer exit is now 39mm was 19mm. Any comments welcome. Clive W
Just curious- what's the make of this 4-valve pushrod thumper.
Generally speaking, 100 HP/L is achievable w/anything approaching a "modern" design, although it may be at the cost of some low end. What's the deal- bike, trike, ATV, a one-off lightweight Morgan?
4V single
My 4 valve motor is DOHC not push rod, it's a Kawasaki KLX650 with a custom pipe and a Keihin FCR 41 carb with a one off bellmouth with 270* roll back. She also has 17" wheels front + back and EBC discs and pads f+r.
| Broken Push Rod in BBC & Oil Leak | S10 Racer | Engine | 1 | 04-18-2009 10:29 PM |
| Push Rod Wall Thickness - BBC | leejoy | Engine | 1 | 03-18-2008 10:18 AM |
| Fuel pump push rod 350/ 400 | Ratchet | Engine | 5 | 05-23-2006 10:54 AM |
| Push Rod Length? Rockers? | bjam2 | Engine | 5 | 09-07-2004 12:12 PM |
| push rod prices | chevypunk | Engine | 6 | 04-18-2003 03:55 PM |
