Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Pushbutton 727 Torqueflite Question
Old 04-13-2013, 07:04 PM
thinwhiteduke's Avatar
thinwhiteduke thinwhiteduke is offline
Living In The Past
Originally Posted by 33Willys77 View Post
If you are going with an aftermarket shifter, why not go with a newer 727? That way you can have the new torque converters too - and get a higher stall if needed. The 2 transmissions have different pumps.
Because I have an early type already, pulled from a drag car, running. Has had bell housing machined off and a scattershield beautifully fabricated from 1/4" plate steel fitted that accepts SBC block pattern. Have the tail shafts made up and high quality 5000rpm stall converter to suit. Also have the pushbutton change which I can use if I have to, but would prefer a floor shift.
Duke
